Powering backup camera with trailer brake plug.
Old Jul 22, 2009 | 12:57 PM
DieselBeast01's Avatar
DieselBeast01
My backup camera is slowly draining my battery each day. It is hooked directly to the battery and this is causing it to drain the battery. I need to know which wire feeds power to the trailer brake plug so that I can try to splice it into that. If there isn't a power feed to the plug, the I guess i will just have to splice into some sort of accessory like the cigarette lighter.
Old Jul 22, 2009 | 01:10 PM
superduty4x4's Avatar
superduty4x4
IIRC it's the big orange wire... if you have an OEM plug it should be labeled on the lid.
Old Jul 22, 2009 | 01:17 PM
DieselBeast01
Yes my plug is OEM...Ill take a look at it thanks a lot.
Old Jul 22, 2009 | 01:19 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have a look at this Clint, it might help you with this. click here
Old Jul 22, 2009 | 01:22 PM
Layson's Avatar
Layson
You probably should stick a switch on there, or hook it up to your back up lights, or just do an accessory wire that turns on with the ignition. Otherwise that camera is on 24-7..
Old Jul 22, 2009 | 01:33 PM
DieselCamper01's Avatar
DieselCamper01
Mine is powered off the reverse light wire.
Old Jul 22, 2009 | 01:50 PM
Stewart_H's Avatar
Stewart_H
When I wired mine up at the Riffraff Tech Day, I wanted it on a rocker switch so I could decide when it's on or off, not just when the truck is in reverse.
Stewart
SilverBullet131313's Avatar
SilverBullet131313
Best way is to just wire it off of the reverse light wire. Otherwise a switch is best way to go.
Old Jul 22, 2009 | 04:07 PM
triskit16's Avatar
triskit16
I too just tapped the reverse light.
TheHern
Dec 19, 2017 12:52 AM
medino03
May 1, 2015 12:06 PM
psicorp
Mar 26, 2014 11:12 PM
Jammin1
Dec 12, 2011 01:11 AM
atcje
Mar 14, 2007 09:29 PM
