Need some brake help
Old Jul 22, 2009 | 10:46 AM
kaduh's Avatar
kaduh
I have a 96 F-150 that I put all new brake parts on, front and rear, and replaced the line from the differential to the passenger side drum. I figured I'd bleed the brakes to replace the old fluid. The problem I'm having is that I'm getting fresh fluid to the passenger rear, but the pedal is still squishy and goes all the way to the floor. I bled the brakes in a normal fashion at first, farthest to nearest the master cylinder and got no air coming out. I have used four pints of fluid trying to chase down this problem. My question is how much fluid does the whole system require, and if anyone has any suggestions on why I'm not getting any pedal response, it will be greatly appreciated. I have to step out for a few hours, but will check back later today. Thanks in advance. This site has been awesome for me.
Old Jul 22, 2009 | 11:49 AM
Lazy K's Avatar
Lazy K
There is an RABS valve module bolted to the inside of the left side frame rail that usually needs bled after brake line work on the rear. Bleed RR, LR and then the RABS module (there is a bleed screw on it).
Old Jul 22, 2009 | 02:29 PM
kaduh's Avatar
kaduh
Thanks, I'll give it a try.
Tried it and got clean fluid from all three bleeders. I'm baffled.
Old Jul 22, 2009 | 03:42 PM
quaddriver's Avatar
quaddriver
actually I bleed the rabs first given that it is inline with the other two and not a branch...
john59923
Sep 18, 2012 08:02 PM
tubehifi
Dec 30, 2010 04:30 PM
DansBBF250
20
Jun 30, 2010 08:45 PM
stangfan78
Nov 8, 2009 01:10 PM
restorit
1978 - 1996 Big Bronco
17
Mar 26, 2002 11:07 PM
