Parts help
Old Jul 22, 2009 | 04:08 PM
dvcroket's Avatar
dvcroket
Parts help
What's the correct name for the sensor that threads into the backside and bottom of the fuel/water separator housing on a '95PSD? Looks like a vacuum line of sorts. Riverrat41 drove dwon a couple of weeks ago and help me put new hoses on the fuel lines behind the fuel/water separator and now it appears I am leaking some diesel from that sensor. Had to remove it to get to that bottom hose. Hoping I didn't overtighten and crack the housing but have been told the sensor can go bad and leak as well. Can't seem to find it at any of the local parts stores but maybe I'm just not calling it by the correct name. Any help/advice would be appreciated.
Old Jul 22, 2009 | 04:21 PM
tford3's Avatar
tford3
I have what I believe are easy to answer questions. '93 F-250 4X4 460ci. What are the general opinions of this (year) engine? Any inherent problems? With the '93 can locking hubs be installed to replace the automatic hubs? Truck has automatic trans w/ floor transfer case shift,( is that how they all were equipped?). Any answers much appreciated. Thanks!
Old Jul 22, 2009 | 04:26 PM
SaikotikGunman's Avatar
SaikotikGunman
Don't know much about the 460, but the auto to manual hubs swap has been talked about multiple times here, and can be done. It's a bit more involved than changing the oil, but is doable.
