Sponsored by: Real Truck
Fog light issue
Old Jul 21, 2009 | 09:33 PM
420CREW's Avatar
420CREW
Fog light issue
Does anyone else's passenger side fog light seem to be dimmer than the driver side or aimed differently? I have checked the wiring and there is normal resistance on both sides and there is no voltage drop difference between the two sides? does anyone else seem to see this with their truck? 2005 f250 cc
Also I am looking for any other free mod suggestions I have already done the door chime and the fog light on with the high beams! Not alot of money right now but I do like mods!
Thanks in advance!
Old Jul 22, 2009 | 06:43 AM
420CREW's Avatar
420CREW
bump bump bump
Old Jul 22, 2009 | 06:51 AM
Lonewolftx's Avatar
Lonewolftx
Wink
You could do the seat belt chime mod as well if you haven't turned it off already. See tech folder . . .
Old Jul 22, 2009 | 10:24 AM
brian42's Avatar
brian42
Veteran: Navy
Thanks in advance!
Your fog bulb might be on the way out. You can't aim the fog lights since they are on a bracket that bolts to the truck...but you can add headlight bulbs to them to brighten things up (9005 style headlight bulbs).
Old Jul 22, 2009 | 02:35 PM
420CREW's Avatar
420CREW
I failed to mention that I put new bulbs in to try to fix the issue and it did not change!
Old Jul 22, 2009 | 06:28 PM
420CREW's Avatar
420CREW
does anyone have any other ideas?
Old Jul 22, 2009 | 06:34 PM
sailorman3's Avatar
sailorman3
Brightness, I cannot help you with. But my 09 250 has a screw so that you can aim the light seperate from the bracket.
Old Jul 22, 2009 | 07:19 PM
Desert 4x4's Avatar
Desert 4x4
guys you can adjust the factory fog lights up and down but, you can not adjust them left or right
Old Jul 22, 2009 | 07:30 PM
willie00's Avatar
willie00
Trailering
On what circuit did you check resistance? Check for voltage drop/resistance on the ground (negetive) side.
Old Jul 23, 2009 | 06:36 AM
420CREW's Avatar
420CREW
Smile
I tested on the ground side.
How do you adjust the height?
Old Jul 23, 2009 | 06:41 AM
Downriver Thunder's Avatar
Downriver Thunder
Also I am looking for any other free mod suggestions.....and the fog light on with the high beams!
How do you do this one?
Old Jul 23, 2009 | 10:30 AM
Deluxe05's Avatar
Deluxe05
In the Foglamps with highbeams on, info here: thread!
Old Jul 23, 2009 | 10:33 AM
brian42's Avatar
brian42
Veteran: Navy
http://www.ssdiv.com/fog.html
Old Jul 23, 2009 | 11:03 AM
dkf's Avatar
dkf
Anyone ever run into a problems with the high beam foglight mod during a state inspection? The mod would be illegal in my state because highs count as 4. Years ago my dad had his fogs wired to a switch on the dash. he took the truck in for inspection and the garage rewired it so the fog lights didn't come on with the highs. They wouldn't have past it the way it was.
Old Jul 23, 2009 | 11:34 AM
ziggy115's Avatar
ziggy115
I had to adjust my fog lights on my 05 250.I had the same issue with one that looked brighter.I backed my truck into the garage,closed the door, shined the lights on the door and noticed that one was higher.It was kind of a pain to reach up in from the bottom to adjust but that fixed my issue!!!
