rubbing/vibration noise
Old Jul 21, 2009 | 07:53 PM
jle70's Avatar
jle70
I noticed the other day after pulling my travel trailer, at higher rpms a vibration/rubbing sound from the engine area. I looked over everything and cannot find anything loose or any signs of rubbing. Any thoughts?
Old Jul 21, 2009 | 08:46 PM
F250Growler's Avatar
F250Growler
have you checked your entire exhaust system? i found the other day that my down pipe had worked loose from the turbo and the clamp was half way on and at high rpms it was rattling like marbles in a wooden box.
Old Jul 21, 2009 | 08:57 PM
jle70's Avatar
jle70
Yep. And I did find that clamp loose awhile back and it is still tight.
Old Jul 21, 2009 | 11:20 PM
pjwoolw's Avatar
pjwoolw
Engine and transmission mounts good? Check the fan shroud for signs of rubbing. WAG
Old Jul 22, 2009 | 04:12 PM
mcdavidson's Avatar
mcdavidson
My Downpipe shifted back at some point and was hitting the firewall occasionally, (turning corners etc.) BIG HAMMER and a crow bar...
