AC question.
Old Jul 21, 2009 | 06:51 PM
AnOldDog's Avatar
AnOldDog
AC question.
You may recall that I broke my back. I've been wearing this plastic turtle shell TLSO brace and it is miserable when the weather gets hot. I'm starting to wonder if the AC on my '01 F150 SuperCrew is starting to get a little weak.
It may be the brace, but it seems like it takes a long time for the cab of the truck to chill down. It tends to blow fairly cool air, but it doesn't seem like ice cold air. How can I tell if it is right?
It's getting close to 10 years old and has never had an AC service. Anyone have gauges? Anyone have any experience with the parts store kits? I am currently unemployed (disability from back injury), so money is a really big issue.
Thoughts, suggestions?
chet
Old Jul 21, 2009 | 10:51 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
I have not worked on an AC system since 1984. I have not used the store bought kits. Sounds like you just might need a simple recharge. or there could be a leak in the system. Don't know anyone with gauges though, so I can't help much on that issue. Maybe someone in the chapter has some gauges, and lives a bit closer can help out.
Old Jul 22, 2009 | 10:52 AM
TigerDan's Avatar
TigerDan
Chet, you can buy a simple little thermometer (kinda looks like your basic meat thermometer) at most auto parts stores:
You simply stick it into the center vent as shown and with the A/C blowing full cold, let it settle in then read the temp. This should show you whether it's the A/C or you. I realize you don't have a basline reading to go off of, but your A/C in good shape should be putting out somewhere in the 35º-45º range. If you're up in the 50ºs or even 60ºs then some attention to the system is probably needed.
If you do need to top off the system, you can buy a simple little single gauge at the parts store along with a can of R134a. Beware of the kits however...DO NOT buy a kit or any can of R134a that has Stop Leak in it, this can kill your A/C system over time. Yes, it will plug the leaks, as well as plug things that you don't want plugged.
Old Jul 22, 2009 | 04:09 PM
AnOldDog's Avatar
AnOldDog
The thermometer is a great suggestion. Thanks. I'll go pick one up tomorrow morning (when it's cooler).
Chet
PS. Only one more month and this damn brace is gone.
Old Jul 23, 2009 | 12:44 PM
AnOldDog's Avatar
AnOldDog
Looks like the AC is doing OK. With an outside temperature of 74 degrees, the thermometer was reading about 42 degrees. Thanks for the tip.
Old Jul 23, 2009 | 12:48 PM
TigerDan's Avatar
TigerDan
Check it again later in the day when it gets hotter outside, see if the A/C is still putting out in the low 40s or not...
BOB FERGUSON
Jul 24, 2013 08:32 PM
raytasch
Oct 13, 2011 12:26 PM
odb2888
1978 - 1996 Big Bronco
Jul 16, 2003 11:34 PM
WC76TX
May 10, 2002 02:10 AM
bob w
Jun 21, 1999 09:52 AM
