Transmission swap
Old Jul 21, 2009 | 10:39 AM
oldblue166's Avatar
oldblue166
Transmission swap
Would like to swap the fx transmission in a 66 f250, 352, to a c6. has anyone tried this or will it fit.
Old Jul 21, 2009 | 11:37 AM
jowilker's Avatar
jowilker
A FE bell C6 will work. The driveshaft connection is different and you probably will have to have once custom fitted or cut.
John
Old Jul 21, 2009 | 11:47 AM
airharley's Avatar
airharley
You may also need to move the crossmember back a little. Do you have the 2 piece or 1 piece driveshaft on your truck?
Old Jul 21, 2009 | 01:25 PM
66f-100's Avatar
66f-100
I did this swap and it is definately worth it. It went a lot easier than I expected. You will have to slide the transmission crossmember back since the transmission mount is a little further back on the C6 and drill 2 new holes to remount the crossmember. The transmission mount for the C-O-M and C6 are identical. You will need to buy cooling lines for the trans and run them to the radiator. I bought a new yoke and had a one piece drive shaft made. Cost me about $200 for the drive shaft. Make sure that you either get the C6 from a truck or get the shifter arm from a truck so that it will go in all gears.
Old Jul 21, 2009 | 02:05 PM
oldblue166's Avatar
oldblue166
It has a 2 piece driveshaft.
Old Jul 22, 2009 | 04:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Not that it matters inre to the swap...
It's a MX Cruise-O-Matic, not an FX.
The FX C-O-M was used in some 292's.
Old Jul 22, 2009 | 05:14 AM
jowilker's Avatar
jowilker
Not that it matters AT ALL
John
kenp
Aerostar
Jan 3, 2003 12:38 AM
Mauser8mm
Bronco II
Dec 20, 2002 11:49 PM
davido
Jul 29, 2002 08:23 PM
alpo23
Sep 24, 2001 03:37 PM
DannyP
May 26, 2001 03:39 PM
