74 4x4 f250 hiboy fuel tank
Old Jul 25, 2009 | 08:46 PM
  #31
TOM B1's Avatar
TOM B1
I think EASTWOOD sells that gas tank stuff
www.eastwood.com
Old Jul 25, 2009 | 11:41 PM
  #32
Notmeofficer's Avatar
Notmeofficer
I have an almost like new tank out of one of my f600s (1973 vintage)... behind the seat.... which I think is the same one you are referring to... its a non emissions tank
Let me see if Im going to use it or not.. and if not Ill post up here and let you know
notme
Old Jul 26, 2009 | 02:36 PM
  #33
Todds79's Avatar
Todds79
TOM B1
I have pictures in my gallery of the Bronco II tank install. Now I have room behind my rear seat for subs and amps. Although mine is a crew, the frame width is the same, and it is a pretty easy swap--once you pull the bed. I did have to move a crossmember back a few inches to make it work correctly.
I don't know why the Pinto tank was even brought into this thread--Ford trucks have had the gas tank in this same position for years with no troubles. My 79 has the original tank mounted behind the rear axle. The strength of an f-250 frame isn't even a comparison to a Pinto. Mine works great and I have no safety concerns at all.
Old Jul 26, 2009 | 04:40 PM
  #34
TOM B1's Avatar
TOM B1
Just what I needed, Now to get busy restoring my truck.
THANKYOU
Old Jul 26, 2009 | 04:45 PM
  #35
armstrongfordtrucks's Avatar
armstrongfordtrucks
Get the one from JC WHITNEY it is plastic. If you search my posts there is a part # for it if you can't find it in the catalog.
Good luck
Old Jul 26, 2009 | 09:21 PM
  #36
kyhiboy's Avatar
kyhiboy
www.eastwood.com
They sure do.
http://www.eastwood.com/ew-gas-tank-...-for-cars.html
Old Apr 7, 2016 | 11:01 AM
  #37
skyfall_89's Avatar
skyfall_89
You might try looking up LCM truck. They have a lot of parts for older trucks. Might have the tank you're looking for. Or see what a welding shop would charge to fix the one you have.
Old Apr 7, 2016 | 11:27 AM
  #38
PA74F250's Avatar
PA74F250
It'll soon be 7 years since this was posted he probably figured something out.
Old Apr 8, 2016 | 01:22 AM
  #39
co425's Avatar
co425
Originally Posted by bigdavesohc
What is the difference between a 67-72 and my tank? What do I need to do to make it work?
The 67-72 in cab tank will work. I had one in my Highboy. If I remember correctly a couple of the top holes were off. Also for the bottom mounts I had to make two L tabs to hold the tank. It bolted into the cab floor and a bolt with a small threaded square to pinch the pinch weld on the tank to keep it in place. I cannot remember if this was due to the mounts being different or if I just could not locate a factory bracket set.
76flatbed
16
Dec 7, 2025 10:50 PM
willymakeit
29
Jul 28, 2017 01:28 PM
1974xlt
May 19, 2017 10:01 AM
jmariani
Feb 12, 2017 08:47 AM
Amphihauler
Jan 29, 2017 02:43 PM
