opinions?
i know that this may open up a can of worms here, but why is it that everyone has to run real good oil in their rides? I mean, i run this el cheapo wal-mart tech 2000 stuff in all my trucks BUT i drain it at every 1500 miles when it starts getting really grungy looking. I have yet to have any oil related failures or major engine catstrophies. I dont know if that can be attributed to the oil, the drain intervals or pure luck. In any event, i think the higher cost oils are a waste of $$$. Heck, if you drain it out routinely, arent you preventing sludge buildup that these fancier oils claim to eliminate also?---i guess I just dont understand these oil debates at all....anyone care to shed some light or educate me if im missing an important concept with regard to this issue?
THANKS
~~NUT~~
By the way how the freak does your oil get so dirty in 1500 miles! What do you do let it idle all day long?:-staun
yr guess is as good as mine on how the oil gets so darn dirty. I rarely let my truck idle for long periods and the motor seems pretty healthy (minimal blowby). I use the truck mainly to haul firewood and landscape supplies and i notice that every time i change it, it QUICKLY goes from a light beige to almost coal black. I figured that the oil is cleaning something inside! The past history of the truck is not well documented. I was thinking of running a cup of diesel fuel in it and letting it idle for a few mins under NO load to clean it out some but diesel, like kerosene, is a strong solvent and i DONT want to strip off all boundry lubrication and **** up the bearings!
regards
~~NUT~~
INLINE SIX POWER!
'95 F150 XL300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be time for automatics when you're old and unable."
It wouldn't scare me at all to drain all the oil and refill with diesel and let it idle for 20 minutes. Drain. And refill with your favorite oil. If you're worried, pull the valve cover. That usually gives a good indication of how much buildup is inside the motor.
Every time I change my oil, it looks "black". As many of you know I've had several (4 or 5) samples tested and they were all "black" when I sent them to the oil lab. They all passed the oil test with flying colors.
I never think much about the oil being so dark. It's been used for 3 - 4 - 5,000 miles. Everything I can see in the valve train is spic-and-span, so I don't worry about it.
What about you guys? What does you oil look like when you drain it?
Brian A
just out of curiosity, i went outside and pulled the dipstick and guess what? the crap that is in there smells really foul; wreaks of a strong gasoline odor! I know the float is not leaking nor am i running excessively rich! I wonder if this is what is oxidizing the oil
I couldnt imagine what would happen if i sent a sample of my oil out to be tested! The lab would prob tell me that my vehicle is an environmental AND health hazzard! Im going to change the oil sunday again and i think im gonna stuck some pennzoil pure base junk in there and see how long that takes to turn black. guys, FYI, last time I pulled the valve covers, I had thick caked on junk all around the valves. I chipped most of the hard stuff out and cleaned the rest off with a paintbrush and kerosene. It looks pretty clean now but yet the darn oil comes out murky....gotta love the ole fords....
regards
~~NUT~~
>fords....
>regards
>~~NUT~~
Have you tried the ATF trick? Apparently, since ATF is so detergent, you can drain the engine, refill with ATF + filter, run it for 10-15 minutes, drain, repeat, until the ATF comes out clean. It would seem that it's a lot better than runnining those harsh engine flushes.
XXL
)>just out of curiosity, i went outside and pulled the
>fords....
>regards
>~~NUT~~
Yikes! If you are chipping off crud then this is dangerous for your engine. There is a safer modern way to clean the inside of your engine using ester technology. I just ordered 3 bottles of this ester based cleaner called Auto-Rx (www.auto-rx.com) to use in my Toyota V6 that's known for sludging up and will use the same stuff in my transmission. It basically disolves sludge and deposits and converts them to liquid goo that get's stuck in the oil filter, and it isn't a solvent like kerosene. You run it for 500 miles in fresh oil and filter and then change it out. You probably need 2 treatments from the sounds of it.
i know that this isnt normal but we shall see...regards
Ben
