front end issue(s)
Old Jul 20, 2009 | 06:43 PM
bloodline666's Avatar
bloodline666
front end issue(s)
when turning left a slow speed in idle. like pulling into driveway or parking space i heard this rubbing grinding noise. a friend told me prob. hub ***. so i replaced both about 2 weeks ago.i am also getting a steady shimmy in steering wheel. a few months back i replaced end links sway bar bushings shocks and just put new steering stabalizer in it over the weekend. any input would be great. thanks in advance.
Old Jul 20, 2009 | 06:48 PM
KRDiesel's Avatar
KRDiesel
Do you have the stock size tires and rims?
Old Jul 20, 2009 | 06:50 PM
bloodline666
yes they are and the air is at 75#.
Old Jul 20, 2009 | 06:52 PM
12ozd's Avatar
12ozd
Front left wheel bearing?
When you say hub replacement,do you mean the wheel bearing assy., or the 4 wd. locking hub?
Old Jul 20, 2009 | 06:53 PM
KRDiesel's Avatar
KRDiesel
Jack the front up and put it on jack stands, Have a friend turn the wheel back and fourth, look to see if it is touching anywhere.
bloodline666
i replaced the hub assembly on both pass. and drivers. 2 weeks ago.
Old Jul 21, 2009 | 07:01 AM
MaxOut's Avatar
MaxOut
This may be a stupid question but are you stuck in 4WD? In 4WD on dry pavement you will get resistance and what sounds like a grinding sound when making turns.
Old Jul 21, 2009 | 09:15 AM
brian42's Avatar
brian42
Veteran: Navy
The shimmy could be an alignment issue.
Old Jul 21, 2009 | 09:29 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Has the truck been lifted? Is there and play in the pitman arm?
Old Jul 21, 2009 | 10:01 AM
bloodline666
both hubs are in auto mode. i dont feel any play in pitman arm. truck is stock.im baffled. and really dont wanna pay out my but for the dealer to fix it. if i could figure out the prob. i can fix it myself and save some cash for my pocket.
Old Jul 21, 2009 | 03:13 PM
Bustaduck's Avatar
Bustaduck
I thank it is bearing in left front wheel
Old Jul 21, 2009 | 05:56 PM
foul1's Avatar
foul1
I have a dodge that when the brakes are hot the front left caliper will hang up causing a shimmie? Had a suburban with warped roters acted like a stuck rotor? (bad) Funny the wife drove both.
crobotti
Apr 9, 2014 10:35 AM
belas
Jan 8, 2012 07:07 PM
bad ass diesel
Aug 21, 2009 06:58 PM
leviticus
Jul 3, 2008 03:56 PM
rerod
Dec 17, 2004 04:26 PM
