trailer lights not working
Old Jul 20, 2009 | 05:18 PM
dustys7.3psd's Avatar
dustys7.3psd
I dont think that i have a fuse box under the hood.
Old Jul 20, 2009 | 05:22 PM
duck fan's Avatar
duck fan
Because racetruck
I promise you do. Its in the corner of the driver's side fender and the firewall. Between the fender and the master cylinder.
Old Jul 20, 2009 | 05:28 PM
tdpower's Avatar
tdpower
He has a 2003. They moved all the fusses to the cabin compartment in 2002 I believe. I would suspect a relay or fuse as well.
dustys7.3psd
ok i have two little boxes which both have 3 relays in them but not numbers or anything that indicates what they may be for.
Old Jul 20, 2009 | 05:35 PM
duck fan's Avatar
duck fan
Because racetruck
Went back and read that. I swear the last time I read that post it said 2000. I need a nap.
Old Jul 20, 2009 | 05:40 PM
zx250's Avatar
zx250
Of the next Riffraff East
Are you checking voltage against the truck or ground on the plug? You need to pull the fuses and check the them with a meter. They may look ok, but still be bad.
Did you get the link where you can download you a owners manual?
Old Jul 20, 2009 | 05:44 PM
dustys7.3psd
Got it. It was a blown #6 fuse (Trailer tow turn/stop relay). Thanks for all the help guys and the owners manual online.
Old Jul 20, 2009 | 05:55 PM
zx250's Avatar
zx250
Chit, I guess I missed seeing that was a fuse. Glad you found it.
Old Jul 21, 2009 | 07:49 AM
RFD_Truckie's Avatar
RFD_Truckie
Take the covers off, and turn on a turn signal. Listen for the clicking relay and thats the trailer brake/turn relay box. the two smaller ones are the ones your looking for. Check out https://www.ford-trucks.com/forums/8...g-a-relay.html Its a thread that I have started since I am having the same problem. In my situation, I dont have constant power going to these two relays.
Hope you just need to change relays...
coreyallan01
Jun 29, 2017 04:48 PM
finitetime
Mar 24, 2017 10:02 PM
4x4pwr
All Things Towing
May 15, 2016 06:42 AM
Blue_Moose
All Things Towing
May 20, 2008 01:36 PM
92GT5ohRed
Electrical Systems/Wiring
May 7, 2005 05:03 PM
