I have the 302 with 67k miles on it and it has a knock in the engine when moving down the road but not in idle or if i rev the engine when sitting. ive tried to put some additives in the engine to reduce wear but nothing has happened?
If you have some jackstands, or even cinder bricks or blocks will work if you have enough of them and a flat, stable surface, raise the drive wheels up off the ground, then start it and put it in gear. If it's only knocking while driving, then this should hopefully replicate the knock. It's not putting the engine under as much load as when you're driving, but it might be enough.
Then, being extremely careful not to interfere with moving engine parts [ie get your hand caught in the belts ], you can use a small chunk of conduit, solid rod, or a long screwdriver to help isolate where the knock is coming from. Just place one end on random areas of the engine [valve covers, intake manifold, heads, etc] and the other against your ear. This is more difficult to do with a piece of conduit as conduit tends to make sounds echo inside it, but you can isolate the source area of the noise which will then help with a diagnosis.
I do want to warn you tho- the more you run the engine with the knock, the more the possibility of serious engine damage grows. If at all possible you should quit driving the vehicle until a diagnosis and repair can be made.
Keep us updated.
If by "cinder bricks" you mean the hollow cinder blocks used to build buildings, I do not believe they are safe to put a vehicle on--they break VERY easily, (relatively speaking) and can have cracks in them that are next to impossible to spot, until they let go, do to their rough surface. Vehicle frames concentrate all the weight on a few points, whereas when used in a building, the weight on the block is evenly distrbuted, rather than concentrated in a few small points.
Use jack stands or solid timbers, but preferably jack stands.
