Tranny question
Old Jul 20, 2009 | 01:24 AM
salf100's Avatar
salf100
Tranny question
Anyone know how much power and torque my stock tranny can take? I plan on making some mild upgrades to my engine i.e. new carb, intake, headers and possibly a mild cam. Any info and expirences would be ord great. Almost forgot.....1964 F100 2wd, with 292 and 3 on the tree.
Old Jul 20, 2009 | 05:31 PM
airharley's Avatar
airharley
Think you can verify the actual 3 speed mounted? There are a few flavors out there including one with a overdrive function. Pull some casting #'s off of it to post on here and it might be easier guesstimate which one you have if the data tag is long gone. Or losts of picture can speak more.
Old Jul 20, 2009 | 09:58 PM
garbz2's Avatar
garbz2
A stock light duty will handle all you can give it until it breaks.
Cam swaps on a 292 are a PITA, Be prepared as it is not a in the truck type swap.
Garbz
Old Jul 21, 2009 | 04:17 AM
salf100's Avatar
salf100
I work nights, so I will get those cast # soon. Garbz2, thanks for the info on the cam. I plan on doing a complete rebuild on the motor, can you recomend a cam? Somthing mild, just looking for a bit more power.
Old Jul 21, 2009 | 08:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's only two possible 3 speed manual transmissions a 1964 F100 could have...as original.
1) Ford Type 3.03 3 Speed all Syncromesh Manual Transmission.
2) Borg Warner T-86 3 Speed Manual Transmission with Overdrive
The 3.03 was used in F100/250's from 1963 thru 1996, 1967/91 F350's, 1966/77 Bronco's, 1969/74 Econolines.
Dozens of different passenger cars 1963/80, including 1963 T-Bird 390 4V & 6V, 1963/67 Galaxie 390 4V, 6V and 8V.
6V = 3 2V carbs / 8V = dual 4V carbs.
Old Jul 22, 2009 | 08:19 PM
salf100's Avatar
salf100
Ok, so I did some looking and the tranny I have is the light duty 3:03, model # HEF-Z. Hope this helps. Thanks guys
Old Jul 24, 2009 | 06:55 PM
wills 64's Avatar
wills 64
iam trying to put a for speed with OD in a 64 f100 with 223 ci . Not shure that it will fit.
the tag # on trans: D8T RMA 0352. need help on finding what this came out of,and will
it fit in my rig. thanks will 64
Old Jul 24, 2009 | 07:32 PM
BarnieTrk's Avatar
BarnieTrk
Hey Will,
I don't know about the tag # you have, but do you have a picture of it?
Here is a link to a picture of what I think you may have:
http://www.broncoforum.com/forums/sh...d.php?t=107159
Scroll down to post #6.
It's an aluminum, toploader style, with the shift tower out the top.
It is model: T170FT (Code-RTS) and is a 4-speed with 4th being Overdrive.
BarnieTrk
Old Jul 24, 2009 | 09:00 PM
garbz2's Avatar
garbz2
Nope as it is either a SROD or TOD and has the incorrect bolt pattern and input shaft length. All that fits the 64 down bell ousing and pattern pattern are 64 down transmissions.
Check out John Mummerts site for a 223 kit to mount a T5 out of a mid eighties mustang with a six.
Garbz
Old Jul 25, 2009 | 01:43 AM
NumberDummy
the tag # on trans: D8TR MA 0352.
D8TR-MA / D8TA-MA = New Process 435 4 speed manual = 1978 F100/350.
Old Jul 26, 2009 | 11:19 PM
salf100's Avatar
salf100
Numberdummy, you said my tranny (3:03 3spd) was availble until 1996, does that mean I can convert mine to a floor shift with 96 year parts? Does anyone make floor kits for these trannys?
Old Jul 27, 2009 | 03:35 AM
NumberDummy
AFAIK, the only vehicles that used the Type 3.03 3 speed transmission that have a floor mounted shift lever were 1963/64 Galaxies / 1966/69 Fairlane/Torino's / 1965/73 V8 Mustangs.
The chances of finding all the parts NOS, or in decent used condition from any of these cars will be slim.
F100/350's, Econolines, Bronco's and the other passsenger cars: The shift lever is on the steering column.
Old Jul 27, 2009 | 12:00 PM
zacm's Avatar
zacm
Didn't the 3.03 also come in '67+ Mustangs with the six cylinder? Maybe find a guy changing over to a V8 drivetrain? But I'd think you might be looking for awhile before you found a complete set-up.
Old Jul 31, 2009 | 10:51 PM
78ltd's Avatar
78ltd
Floor Shifter
Well Maverick/Comet and Granada/Monarch also had optional floorshifter for the 3.03, but they are rare. I had to buy a Mustangone for the floor shift. And yes, 67 up Mustangs used the 3.03 with the sixes. Earliest use I know of the 3.03 with a six was the 170Bronco's.
Fird12
Feb 18, 2015 03:49 PM
FECruzer69
Jul 27, 2010 01:22 PM
Krisx125
Jun 17, 2010 05:51 AM
Snapper_Rider
Offroad & 4x4
57
Sep 28, 2004 06:33 PM
bobbo2tone
Aug 5, 2002 08:00 AM
