Plow
Old Jul 20, 2009 | 12:01 AM
BAD351W's Avatar
BAD351W
Plow
Would a plow from a 1986 F-250 fit my 1996 F-250?
Old Jul 20, 2009 | 12:07 AM
DBGrif91's Avatar
DBGrif91
Even if it's not a straight swap, I don't see why you couldn't make the necessary modifications to make it work.
Unless you don't have any way to make the mods...
Old Jul 20, 2009 | 01:03 AM
9.ford.5's Avatar
9.ford.5
i believe the frames are the same and if they are all the brackets and stuff will swap over
Old Jul 20, 2009 | 11:05 AM
BAD351W's Avatar
BAD351W
My boss at work has a 1986 F-250 that hes going to get rid of through the cash for clunkers program. So hes got a 7.5 Fisher plow that I can get for $500. If it fits my truck, im definitely going to get it.
Old Jul 20, 2009 | 12:43 PM
linckeil's Avatar
linckeil
I just junked my 1986 F250. the front frame horns are different. the plow would not swap to my 1996 F350 - but with modification it will. the interchange years are:
80-91 F250/F350
92-96/7 F250/F350
and by the way, your truck should really have an 8 footer on it. you'll find 7.5 to be a bit too small.
Old Jul 20, 2009 | 12:47 PM
northeaster79's Avatar
northeaster79
it should be very similar but your 96 will have the crumple zone at the front of the frame,which I don't believe the 86 had,I bought plow gear of a mid 80's 250 for a 92 we had here at work and it fit,but we had to make a few minor modifictions.but even if you have to do that at $500 its well worth it.the blade is owrth 500 alone.
Old Jul 22, 2009 | 01:57 AM
BAD351W's Avatar
BAD351W
So the plow will indeed fit?
Old Jul 22, 2009 | 06:15 AM
northeaster79
yes it will fit.
Old Jul 22, 2009 | 07:25 AM
linckeil's Avatar
linckeil
anything will fit with enough modification. what you are trying to do is no exception. you will have to modify it. re-read my post above. i am taking a setup off an 86 and putting it on a 96 just like you are. it will indeed fit, but be prepared to cut/grind/weld to make it work. i gave you the direct swap interchange years above.
Old Jul 22, 2009 | 12:16 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
NO
but you can do by add shim on both side to get fit.
I believe 86 frame should be 41 or 42" and 96 should be 40 or 41". 80-91 model bronco to F350 will fit that mount.
Need drill in mount to get frame right.
isn't it permanent mount with front bumper? Do not put on 96 it illegal it for 1994 or old due law.
19-F250-78
May 8, 2016 08:02 PM
Stu13
Oct 28, 2011 04:00 PM
Black Snow Slide
6.4L Power Stroke Diesel
Dec 23, 2010 03:24 PM
firefytr29wfd
Jul 2, 2007 10:22 PM
