turning off the headlights with engine running
Old Jul 19, 2009 | 07:29 PM
Ridgrunr's Avatar
Ridgrunr
Here's the setup. At the drive-in (yup we still have one), double feature. Sound plays through the stereo. Between features I want to start the truck to keep the battery charged. Can't turn the lights off, everyone is honking at me. Is there a way to turn the headlights off with the engine running? Can't find anything in the book. Guy next to me says to put the emergency brake on with the lights in the big O selection. Doesn't work. Honking gets worse. Had to shut it down to avoid a lynching.
2008 F150 4X4 Super Crew. My headlight switch has 4 choices,
Auto
Daytime running (big O)
park
on
Thanks
Ned
Old Jul 19, 2009 | 08:11 PM
spatts's Avatar
spatts
You Must Be Lost ? This is a 04-08 F-150 Ford Forum not Chevy.......LOL
I never realized Ford had day time running lights on any of there models ?????
Old Jul 19, 2009 | 08:50 PM
shorebird's Avatar
shorebird
Page 91 here; http://www.motorcraftservice.com/pub.../08f12og1e.pdf
Old Jul 19, 2009 | 09:01 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
@ Shorebird
link doesn't work unless you visit http://www.motorcraftservice.com
On the Left click "Owners Guides"
The new page is where you can input your Ford info and select the Owners Guide.
That will bring up the Manual specific to your truck
You in Canada by chance? USA spec'd trucks don't have running lights. Canadian spec'd trucks do.
if you are in Canada, or have a Canadian truck, you have to pull the DRL relay. It's in the engine bay with the main wiring harness fuses.
Old Jul 19, 2009 | 09:17 PM
FTE Trigger's Avatar
FTE Trigger
I'd go with Tylus here... The DRL relay is the simplest...
For what its worth, I was wanting to get the OEM DRL set-up on my truck. I just never ordered the kit from my parts people. I'll have to keep this scenario in mind before I make the plunge.
On a side note:
Tylus what browser are you using that's not allowing you to access the Motorcraft PDF links?
Old Jul 19, 2009 | 09:26 PM
Ridgrunr's Avatar
Ridgrunr
Damn, thing says Ford all over it. 5.4 Triton and all. Don't know if you'd call 'em running lights or not, but my Ford Owners guide calls em Day Time Running Lamps, bottom paragraph of page 92. They just come on when it's in the O postion, but they aren't near as bright as when it's in the "On" or "auto" position. Sure appreciate you not having any usable information though.
Old Jul 19, 2009 | 09:28 PM
Ridgrunr's Avatar
Ridgrunr
Originally Posted by tylus
@ Shorebird
Nope, good ole USA.
Old Jul 19, 2009 | 11:52 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
My browser pulls up .PDF files just fine. But if you haven't visited the Motorcraft site recently, their links don't work. You have to have a recent cookie to be able to pull up a link like Shorebird posted...sucks, but not that hard to get around.
For the OP: so you truck is either a Canada spec'd truck, or it's like my Expy. Somebody at the Dealership ordered it with the DRL Kit.
There is no way to turn off your DRL. You have to pull the DRL fuse. Follow the link above and pull up your Owners Manual
it was on page 306 when I was looking. Had a schematic of the fuse panel and even showed the relay.
Old Jul 24, 2009 | 04:17 PM
scans's Avatar
scans
Shouldn't the DRL feature only operate the Fog lights... not the headlights.
taken from manual:
Daytime running lamps (DRL) (if equipped)
Turns the foglamps on at full intensity output. To activate:
• the ignition must be in the ON position and
• the headlamp control must be in the OFF, parking lamps or autolamp
position.
I have the same issue with the headlights. They are always on... no matter what position the switch is in.
Old Jul 25, 2009 | 10:04 PM
stronger's Avatar
stronger
my old 150 is an '05, I can shut mine running lights off, obviously you guys can not, but if you only watching a movie or two....why worry about charging the battery? I have a co-worker who pulls his '07 up and leaves the radio on for 4-5 hours to a rip, twice a day, regularly. sometimes it goes 8 hours if he forgets and leaves it on if we go for lunch with my truck. starts ever time.
Old Jul 25, 2009 | 11:34 PM
GwarForAll1021's Avatar
GwarForAll1021
i know for a fact that all the work truck options come with DRL cuz my 05 F150 and the 06 F250 work trucks have them
how to turn them off? i have no idea im just saying that they do have them here in the good ol us of a
good luck!
Old Jul 25, 2009 | 11:48 PM
Fishin76's Avatar
Fishin76
No DRL's on my 04, but i did have to shut of the courtesy lighting when shutting off the truck in the dark.
Old Jul 28, 2009 | 01:34 PM
bigknuckles's Avatar
bigknuckles
Thumbs up
Unplug the DRL Resistor. I've done it and it works. Plug it back in after the movie and you have DRL again.
Here's where to find it:
http://prweb0.voicenet.com/~storm/drl/DRL-Resistor.htm
JRD761
6.7L Power Stroke Diesel
Sep 26, 2016 08:57 PM
Big-Red-Lariat
2015 - 2020 F150
Jun 22, 2016 03:57 PM
twtcad
2015 - 2020 F150
Apr 25, 2016 04:12 PM
meborder
Jan 29, 2014 02:43 PM
gascan
42
Dec 6, 2010 03:28 PM
