Ignition switch removal
Old Jul 10, 2011 | 12:33 AM
willj6907's Avatar
willj6907
HELP!
I got the ignition out and i cant figure out how to put new one in. can someone help?
-Will
Old Jul 10, 2011 | 01:39 AM
daveengelson's Avatar
daveengelson
Will, First and foremose, Welcome to the Family of Ford Truck Enthusiast. Key assembly needs to be in same position, accessory, as when it was removed. At the end of the key assembly there's a concentric cam that sets into a corrisponding slot inside the ignition switch. Insert the key, which will be in the off position, there's a small ball on the face of the key assembly, use a paperclip, or something simular, depress the ball while rotating the key counterclockwise, this places the assembly in the 'accessory' position and the cam on the key assembly should now be aligned with the slot in the ignition switch, insert the assembly with the key then turn clockwise. Fortunately I don't have to make sense of this pathetic explaination, but if you take a close look at the switch and key assembly hopefully it will make sense.
Old Jul 10, 2011 | 06:02 AM
duke_boy's Avatar
duke_boy
Man, where I am having a locksmith come out is handy. 30 bucks. Seems pricey but not having to drill out a tumbler is worth the 30.
I'm amazed at how quick they can pick the tumbler and have it turned. Good luck getting yours up and running!
Old Jul 10, 2011 | 10:10 AM
willj6907's Avatar
willj6907
i cant figure out how to get the lock cylinder into the lock switch
-Will
Old Jul 11, 2011 | 05:01 AM
jowilker's Avatar
jowilker
Don't know why you guys are having issues. To remove a cylinder, you put the key in, turn it to acc. poke a paperclip in the hole, press it, turn the key horizontal and pull it out.
You reverse that move with the exception of the paperclip to re-install the new cylinder. Start with the key teeth pointing towards the door horizontal, poke it in and turn it clockwise. Once it is vertical you can stop, pull the key, or continue turning over to the start position.
If that doesn't get you going, you will have to check a higher paygrade.
John
Old Aug 3, 2011 | 02:09 PM
jde824's Avatar
jde824
$30 is a steal... I called two local locksmiths today. One quoted me $80 and the other $120.
Old Aug 3, 2011 | 02:31 PM
camperspecial65's Avatar
camperspecial65
the lock cylinder goes in only 1 way...its a bit of a bear but its easily done....I had to do mine a few years back...
the door locks are keyed the same as the ignition originally on these trucks....
And theres the key code stamped on it easily read...
- cs65
Old Apr 14, 2022 | 02:11 AM
jerryjohnson's Avatar
jerryjohnson
Originally Posted by jowilker
I believe you would be better off to have a locksmith come out and make you a new key.
You can destroy the cylinder by drilling it out, replace it with a new one.
You can have the lock picked, turned to the left with a paper clip in the hole to horizontal and pull the cylinder out.
You can have a locksmith come out and make you a new key.
Those are your basic choices as I see them.
John
IF YOU HAD OR KNOW SOMEONE WITH A BUNCH OF OLD FORD KEYS ,,SEE IF YOU CAN JIGGLE ONE OVER TOO ASSESSORY
Old Apr 14, 2022 | 04:07 AM
Crop Duster's Avatar
Crop Duster
Welcome to FTE! This is a pretty old thread but someone might find that helpful.
bobinyelm
Jun 10, 2019 09:25 PM
rswhitmore
Aug 11, 2016 07:58 PM
brabey
1997 - 2003 F150
Oct 9, 2015 04:46 PM
tjman
Oct 16, 2009 08:03 AM
medicpg
1983 - 2012 Ranger & B-Series
Jun 28, 2007 01:01 PM
