overhead display not working
Old Jul 19, 2009 | 10:16 AM
frankyford's Avatar
frankyford
Has anyone had their overhead display go out on their excursion and if so, was it a bad bulb or something much more complicated where I need to take it down. Could it also be a fuse? thanks
Old Jul 19, 2009 | 10:30 AM
william_04_x's Avatar
william_04_x
If you can't find a blown fuse, check out this link.. This is a fairly common problem and the fix is simple.. To get the console down, there is a screw in one of the storage compartments.. Remove that screw and the console will pull straight down..
Old Jul 19, 2009 | 11:06 PM
UrbanXX's Avatar
UrbanXX
I have a 03 Excursion and mine started acting screwy after I blew the cigarette lighter fuse. I replaced the 20 amp fuse and it back on track.
03 Excursion
4X4
V-10 Limited
Old Jul 20, 2009 | 05:28 AM
frankyford's Avatar
frankyford
I know this is going to be a stupid question, but where is the fuse panel on this thing. I looked up under the steering column and I saw a black box with screws in it. Is that it or is located somewhere else.
Old Jul 20, 2009 | 07:40 AM
UrbanXX's Avatar
UrbanXX
Once you open the fuse panel and see the black box just go to the right side of the black box and the top will pull off. Do not remove the screws.
fishermanrob
1997 - 2003 F150
Mar 30, 2014 09:43 AM
afonda
Jan 5, 2010 07:21 PM
mfrewing
May 19, 2009 11:09 AM
7.3 Powerstroker
Jul 21, 2006 07:27 PM
