CYLINDER NUMBER
Old Oct 15, 2002 | 01:53 PM
witchdr128's Avatar
witchdr128
Post CYLINDER NUMBER
Got a check engine light and a rough running engine. Autozone said it was code 306, #6 cylinder misfiring. Want to replace that plug and if needed the plug coil. Anyone know which is the #6 cylinder?
Thanks in advance.
Old Oct 16, 2002 | 02:26 PM
Jimmygunz3's Avatar
Jimmygunz3
CYLINDER NUMBER
Here is the cylinder order
4 8
3 7
2 6
1 5
The firing order is 1-3-7-2-6-5-4-8
Hope this will help..
Old Oct 19, 2002 | 10:21 AM
charlesvalentine's Avatar
charlesvalentine
CYLINDER NUMBER
Right on Jimmygunz... If the direction is not clear from the note, #4 is closest to the front passenger seat.
Be happy it was one of those front plugs
99 F250SD EC 5.4L 3.73 285 BFG/ATs...
99 Expy EB 5.4L
Old Oct 20, 2002 | 04:17 PM
witchdr128's Avatar
witchdr128
CYLINDER NUMBER
Thanks, tried replacing plug and coil, did not fix problem. Don't know what to do now. Problem is I can feel the engine misfiring it sort of jerks the car especially when under heavy loads after engine is warm. Idle is fine although it seems a bit slow, do you know what rpm it should idle at?
witchdr128's Avatar
witchdr128
CYLINDER NUMBER
Thanks, replaced all plugs though. Figured it was time anyhow. Still didn't fix problem though.
Old Oct 21, 2002 | 11:24 AM
buzzard's Avatar
buzzard
CYLINDER NUMBER
Idle should be around 600 rpm, warm.
Old Dec 29, 2002 | 07:28 PM
laresa's Avatar
laresa
CYLINDER NUMBER
Did you ever find out what was wrong? Mine 97 Expedition is very sluggish. Took it to Autozone and it is missing on cylinder 2 and 8, so we replaced plugs, wires, and the coil and it still isn't better. Any ideas??
Laresa
Old Dec 30, 2002 | 06:57 AM
EB_EXP97's Avatar
EB_EXP97
CYLINDER NUMBER
Race
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 1, 2016 03:36 PM
Tommy Ride
Jul 14, 2015 08:16 AM
troverman
Feb 9, 2015 05:07 PM
BRONC-OH
1983 - 2012 Ranger & B-Series
Feb 2, 2013 04:55 PM
