1974 jack location
This truck was advertised as a '75 390 Highboy w/ 3" factory lift. After a little research it turns out to be a '74 360 4x4 with 3.14 rear and 3.30 up front. Definitely light duty.
Did Ford ever do factory lifts on non-Highboys?
I'm tempted to drop it back down and the 33" tires need to go. Not interested in a mudder, but I would like to recondition it for another 35 years.
It needs some interior work a little bodywork. Kicking around an AOD conversion. Should be fun. My oldman bought a 66 new and kept it until '93, so it's not too much culture shock.
This site has already helped on a number of issues, so thanks for all the help past and future.
As far as the jack, mine is strapped to the driver's side front inner fender. It's just a little bottle jack, but mine is a 2WD. Since you are supposed to jack up any 4x4 or RWD vehicle under the spring plate on the axle, I would assume that the same bottle jack could be used for 2 or 4 wheel drive.
Someone please correct me if I am wrong.
Reason I ask is behind the seat looks barren off any fixtures.
Also on the gears the tag inside the dr door says 3140 in back and 3300 up front. I figured that meant 3.14 and 3.30.
As stated, those figures are the maximum axle capacities for the front/rear axles.
But, I think you've reversed the figures, as a 1957/79 F100 2WD/4WD has a minimum rear axle capacity of 3300 lbs.
The Dana 44's front axle capacity is a minimum of 3000 lbs.
The same jack was used 1948/79 on F1/F100/F150's and 1978/79 Bronco's: D3TZ17080C replaced 8C17080.
This jack is obsolete as are the other parts. If someone is looking for a new original jack (D3TZ17080C):
GAYLEN C. WRIGHT FORD in Heber City UT has ONE / ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
The same lug wrench (C2SZ17032C) was used 1948/96 on F1/F100/F150's, 1966/96 Bronco's. And...on most 1949/79 passenger cars.
The crank used to raise the jack up/down is the same 1967/79: C7TZ17081A. This is one looong piece.
DALE CARTER FORD in Eaton OH has ONE / B.F. WHITE MOTOR CO. in Stanton TX has ONE.
There is another crank (82Y17081B) that also works which was used from 1938 thru today on many trucks. It's hinged, so it can be folded in two.
MSRP: $32.78 // FTE sponsor: y2kfordparts.com price: $23.60.
The clamp (C7TZ17091A) used to retain the jack to the left fender apron is the same 1967/79.
GREEN SALES CO. in Cincinnati OH has TEN = 800-543-4959.
Just for the heck of it, look inside the spare tire's wheel. The jack was stored there thru 1966, so one never knows.
The AXLE code is listed on the Warranty Plate, but Ford usually did not list the front axle code.
The Ford ID tag for the front axle will be found under one of the bolts that holds the inspection cover on. Do not be surprised if it's missing.
btw: No 390's were factory installed in any 4WD truck. 1968/76 F100/250 4WD: The only V8 available was the 360 2V.
There is no such thing as an F100 or F150 High Boy. High Boy's are 1967/76 and 1977 (before serial #Y20,001) F250 4WD's.
This truck was a mudder/toy. I have paperwork for the Fred Jones Ford Remanufacturing rebuild back in '99. The C4 is currently under warranty with a shop in OKC. From my research I figure that tranny won't hold up well to the big tires and offroad thrashing this truck has obviously seen.
Thanks again for the help.
What 4WD F Series truck of any year came from the factory with a C4 transmission?
None.
What FE engine in a truck...or car...of any year came with a C4 transmission?
None.
Your truck has a C6.
The only 4WD vehicle from Ford that used a C4 were 1973/77 Bronco's which came with 302's.
After looking yes it's a C6. They may have dropped in a 390, the Fred Jones receipt says 390. So I have a little more research to do. Also the rearend has a tag and the front does not.
Here in CA, and in OR, WA, AZ, NV, ID, HI, AK and etc., FoMoCo's authorized rebuilder is Genuine Parts Distributors aka GPD aka Tumador Engine.
I thought the lug wrench would be the crank, no? If not, any certain place for the lug wrench?
Picked up the Ford service manuals off Ebay on disc. If the guy isn't a fraud maybe they will help with illustrations.
I thought the lug wrench would be the crank, no? No.
Parts catalog shows two possible locations for the crank, clipped to the left fender inner apron, or to the core support. No part numbers are listed for the clips, the catalog says "improvise."
On cars with hood prop rods, the plastic clip that secures the rod when it's not in use may work.
this is in a 76 F-250, and the handle and wrench had never been removed from under the seat
