18 in wheels
Old Jul 18, 2009 | 05:19 PM
frankyford's Avatar
frankyford
18 in wheels
I have an 03 excursion 2wd xlt and was wondering if anyone has put on the factory 18 in wheels on theirs and did so without spacers. I'm leaning towards the harley wheels off the F-250. thanks
Old Jul 18, 2009 | 06:24 PM
Monsta's Avatar
Monsta
Sit. Stay.
If you use the 18" Harley wheels from an 04 then you won't need spacers.
I've seen a couple of Excursions with them. They look VERY nice.
Old Jul 19, 2009 | 10:50 AM
cdgofish's Avatar
cdgofish
I'm new to the Excursion but we recently bought my wife an 05' w/V10. It has Ford 18" wheels on it with 275/65/18 Continental Tires. They rub on the front when at full turn enough that the vehicle can't move in reverse because it is rubbing so hard. The rear rubs on the fenderwell when in off camber positions. I believe this is becaus the rear seems to have a little sag to it. It does not sit level from front to back. I have airbags on order to fix this problem.
Old Jul 19, 2009 | 01:15 PM
SFeintuch's Avatar
SFeintuch
cdgofish, You need to get a set of 2" wheel spacers,Hub Pilot style. Your wheels probably came off an '05 up F250/350. Franky Ford Like Monster said '04 Harleys will bolt right on with no rub pronlems. Anything '05 up will cost you extra for a set of spacers. The offsets in '05 changed by about 1 3/4".
Northbrook
6.7L Power Stroke Diesel
35
Feb 4, 2015 11:48 AM
Ultraboy
Jan 11, 2015 08:17 PM
Wilmax
Mar 28, 2014 10:19 AM
quincyj34
Mar 5, 2014 11:30 AM
98woody
23
Aug 8, 2013 09:35 AM
