Sponsored by: Auxito
Changing Tranny Fluid
Old Jul 18, 2009 | 03:21 PM
bobserenity's Avatar
bobserenity
Changed the ATF in my 2002 Ford F150 and found something in the drain tub that I can't identify. Kinda looks like a fishin float with a black rubber seal round the middle, or a small pingpong ball wih a 11/2in. dowel stickin out. Could't figure out where it came from so I left it out?
Old Jul 18, 2009 | 09:47 PM
steve(ill)'s Avatar
steve(ill)
that is in the transmission fill hole when the trans is installed in the truck. they take the filler tube and poke it in the hole, and the plastic corck falls into the pan. you remove it during the first oil change.. no problem.
