Hesitation on 4.2L
Hesitation on 4.2L
I recently got ahold of a 2001 F-150 with the 4.2L and 116k miles. This truck has been sitting for about 15 months now. When i went to start it it started fine and idled great. However, under load (or heavy acceleration) the engine hesitates. There are no codes stored and i just added fuel stabilizer and changed the plugs and wires. After doing this, it still hesitates.
Any ideas on what i should check next? Thanks for all the help.
Thanks for the suggestions. I have replaced the wires and plugs and the problem still continues, but that doesn't rule out a bad coil or distributor. I am going to check the quality of spark sometime with a friend.
Am i thinking correct MAF = mass air flow sensor? Any tips or suggesstions on cleaning this, or just remove, clean with a cleaner, and re install.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Yes, that is the correct assumption. There are cleaners made for electronic sensors available at your local auto parts store. Just be careful to not touch the sensor wire as it is a very fine wire and delicate. It can easily be destroyed.
By the way what brand wires and spark plugs did you install? Good luck!
Jay Slides
11-20-2011 08:33 AM
