power steering burp
Old Jul 18, 2009 | 10:37 AM
keepnthepeace's Avatar
keepnthepeace
power steering burp
Today I found that my 07 crew cab 6.0 was "burping power steering fluid. It looks like it is coming out of the top of the reservoir. It has also started when you hit the brake quick, the peddle seems to puch back. The drivers side front brake is a little sticky and doesnt release all of the ways sometimes. I am not sure if the to symptoms are related or not. Any and all help is appreciated.
Old Jul 18, 2009 | 01:41 PM
dschuffert's Avatar
dschuffert
I had a similar experience when my Hydroboost tube fitting was leaking and letting air into the system. Per a Ford TSB, I replaced the Hydroboost tubing as opposed to retightening it, replaced the power steering fluid, and everything went back to normal. The part was about $45 from Ford, I did the labor myself.
Old Jul 18, 2009 | 07:30 PM
keepnthepeace
I will look at the hoses and see if I can see any leeks. Thanks for the info.
Old Jul 18, 2009 | 10:10 PM
bismic's Avatar
bismic
I would "rep" you, but I can't yet. Give me some time and I will ........
Old Jul 18, 2009 | 10:16 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Got 'em.......
Old Jul 20, 2009 | 05:51 PM
keepnthepeace
What does that mean "rep".
mstiles19
Feb 25, 2013 04:59 PM
ROKRAWL
Nov 11, 2012 06:31 PM
Shake-N-Bake
Apr 20, 2010 03:36 AM
JIM_C
Sep 14, 2008 03:23 PM
angus21601
May 27, 2008 09:48 PM
