460 swap problem. need some opinions
Old Jul 18, 2009 | 10:02 AM
stevedury's Avatar
stevedury
any thoughts are greatly appreciated here. i have a 78 460 from my 2wd mounted in my 78 4wd. the 4wd is manual. i used a new 460 flywheel, 12 inch clutch kit also. L&L mounts for the motor, which seems lined up correctly, as the z bar is aligned from frame to bell housing. my problem is with the np 435. it seems to bind the motor to the point that i can't turn the motor over, even with the plugs out and using the crank bolt. could my input shaft be that out of shape? i can find all gears and neutral easily, but of course that is behind where i think the problem lies. thanks for any and all advice. steve.
Old Jul 23, 2009 | 12:50 PM
kenmt's Avatar
kenmt
No big deal-your input shaft is bottoming out on the end of the crankshaft.Pull it back apart and using a air cut-off wheel,take about 1/8 inch off the very end of the input.Make sure you grind a little bevel back into the end to make the shaft start into the pilot bushing easier.
Old Jul 23, 2009 | 08:35 PM
stevedury's Avatar
stevedury
thanks for the reply. i have done rebuilds on these trucks a few times, but never the swap. i appreciate it.
Old Jul 23, 2009 | 11:35 PM
Thudpucker's Avatar
Thudpucker
Ken that sounds like the kind of information that came with some real bad experiences!
Old Jul 24, 2009 | 04:06 AM
kenmt's Avatar
kenmt
Coulda been a lot worse-luckily the first time I encountered this scenario a good friend just happened by my shop when I was attempting to 460 my '76 highboy.He had experienced the same thing so he knew exactly what to do.L&L will tell you to buy their "special' bellhousing and their $500 flywheel because " a 390 flywheel absolutely won't work".Yeah,right-I've probably done 20-25 FE to 429/460 swaps using a 390 flywheel and they're still going strong.
Old Aug 1, 2009 | 02:25 AM
sippie's Avatar
sippie
I've done a few conversions and found this problem also. What I did is use 2 to 3 manual block plates. This spaces the trans back to keep from bottoming out into crank.The starter still works fine, more than half the bendix engages the flywheel.
Manicford78
Nov 25, 2012 08:12 PM
caddman6425
20
Mar 14, 2010 05:56 PM
stevedury
16
Aug 2, 2009 11:37 AM
Green Streak
Engine Swaps
Feb 12, 2007 09:22 AM
mudcobra
Dec 19, 2005 05:14 PM
