Shuddering transmission-E4OD
Old Nov 3, 2000 | 08:46 PM
snorogue's Avatar
snorogue
whenever i use a lite touch on the throttle pedal i get a very bad shuddering. When i let off on the gas and reapply the gas it either does not do this again or it will repeat after a few seconds.
Now this was a slight problem at one time and i had the tranny flushed with that new system that is at the ford dealer and that seemed to do the trick (for a While) after about 4,000 miles, It's back to doing it worse. Now what i would like to know is if i need to re-flush this transmission again and again every 3000 mile or if there is a fix. I read in some truck mag. addvertisement"stop transmission shuddering, add high presure "thing-a-ma-bob" and stop this". has anybody herd of this. any help would be helpfull. I've been very happy with this truck as it is an 1990 F350 with 157,000 miles of trouble free driving up untill this time. Maybe its time for a tranny rebuild. except for this problem the transmissin operates under all other driving conditions,ie... shifting, accelerating,forward and reverse conditions. thanks for any help.
Old Dec 2, 2000 | 03:21 PM
rch101's Avatar
rch101
I had a similar problem a few years ago with a Chevy Blazer with a 350cid. It was found that the flywheel was cracked. Fortunately it was covered under the warrantee.
Old Dec 2, 2000 | 08:22 PM
Nathan's Avatar
Nathan
It could be the torque converter. Ford has at least two "updates" on the E4s tc. I would say, though, that with that many miles it could be time to have a tranny shop look at it.
Nathan
Old Dec 4, 2000 | 07:06 PM
fordiesel69's Avatar
fordiesel69
Check the (TCC switch) and the torque converter. The tcc switch is what locks and unlocks the torque converter. That is what happened to our 92 ford bronco 129,000 miles. Also with such miles it would be a good idea to have it looked at and possibly rebuilt.
Old Dec 4, 2000 | 10:32 PM
bb79ranch's Avatar
bb79ranch
Try re-torqueing the valve body to transmission bolts, it worked for my father's auto overdrive in a '95 F150 I know it's not the same tranny but it might save you a BUNCH of $$$$$$. I hope this helps in any way.
Todd
BB79RANCH
Old Dec 6, 2000 | 06:12 PM
stingray's Avatar
stingray
Lucky
15
Jul 12, 2021 11:15 PM
coachnichols
1978 - 1996 Big Bronco
Feb 24, 2016 03:18 PM
Bulldog44
2004 - 2008 F150
Aug 14, 2015 11:19 AM
joge
2009 - 2014 F150
Oct 15, 2012 08:06 AM
HawgDawg
Sep 18, 2003 12:42 PM
