Bronco II Ford Bronco II
Backing Plate Question
Old Jul 16, 2009 | 07:12 PM
nijwnfi's Avatar
nijwnfi
My 86 Bronco2 Front Disc Brake Backing Plate is rusted away to nothing on the drivers side. It has 3 bolt holes, and it looks like an air scoop in the front. The only plate I can find to replace it is a flat one. It has 2 holes in front and 2 in the rear. It bolts in, and doesn't interfere with anything. Will this work?
Old Jul 18, 2009 | 09:43 PM
rebocardo's Avatar
rebocardo
It is called a gravel shield, it will work, though you are better off with the cooling vent or not running a shield at all. The plastic pistons are a weak point on B2/Rangers and can seize from getting too hot.
