Sponsored by: Auxito
OBDll Scanner Live Data
Old Jul 16, 2009 | 04:12 PM
F4L956's Avatar
F4L956
Smile OBDll Scanner Live Data
On OBDll Live data what do the ST FTRM1 %, LT FTRM1 %, ST FTRM2 %, LT FTRM2 % mean... what is that for what does it read what is it used for how can you use it trouble shoot any problem etc...basically any info on those readings did use scanner but didnt know what they were for. Am curious as to what its function is... & what would be some good readings on it, I got around -7.8 to pos 4.4 or so but sometimes it would just jump to 38pos. & so on....any info thanks!!!!!
Old Jul 16, 2009 | 11:32 PM
ford2go's Avatar
ford2go
I believe that those are the short and long term fuel trims for each bank of cylinders.
Short term means that it reacts to the current situation. Basically, the O2 sensor tells the computer how things are going, and the computer changes the fuel trim to get the mixture closer to ideal.
Long term is supposed to react to a long term trend in the short term reading. It's supposed to adjust for wear, etc. When long term adjusts, the short term numbers SHOULD drop.
As to the ranges, etc., you'll have to wait for somebody to respond that actually knows what they're taling about. Or, you could try to research it online.
Old Jul 18, 2009 | 07:19 AM
projectSHO89's Avatar
projectSHO89
To do some research, go to www.motorcraftservice.com and click on the "OBDII Theory and Operation" tab on the left side.
The manual for your specific year's model will be a treasure trove of background information.
Old Jul 24, 2009 | 02:39 PM
F4L956's Avatar
F4L956
THANKS GUYS! Projectsho89 great web info... awesome, does come in handy to know, Knowledge is Power.
Old Jul 24, 2009 | 03:44 PM
pintopower8's Avatar
pintopower8
Rich mixture = lean correction and a negative value on your live data. Then a lean mixture will have a positive Rich correction value. Numbers should be within 20-25% based off of a 0 baseline (equivalent to 14.7:1 air/fuel ratio).
Think of fuel trims as a look up table, as you accelerate the engine you will see different numbers because different loads have their own block on the table, meaning different stored presets for different engine loads.
Short term trims are in direct response to your 02 sensors, TP,IAT, MAF, MAP, etc.. They respond by changing injector pulse width to a certain correction amount until they are finally recognized as a long term correction value and it becomes a Long term fuel trim.
If you are reading live data, you want to compare fuel trims, injector pulse width, and 02 sensor patterns to ensure that they are working together properly.
What else do you want to know? : )
daveplot
May 11, 2017 06:55 AM
Fordmom530
Modular V8 (4.6L, 5.4L)
Mar 22, 2015 08:30 PM
fast97ss
Mar 24, 2011 01:10 PM
big_windy
Jan 22, 2010 10:16 AM
rdelp
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 27, 2008 12:53 PM
