Turbine Mag Wheels
Turbine Mag Wheels
I scored a set of 37" OZ radials and want to mount them on a set of Modern Turbine mags. I was thinking I wanted to machine the lug holes to run "normal" lug nuts. I remember 75F350 saying something about machining the wheels for some steel inserts that would allow the use of the "normal" lug nuts. I have called around Google searched and have been unable to find a source for these inserts. My buddy at the tire store said he called the corporate wheel specialist, and that he said that most of the new aluminum wheels don't run the steel inserts, that the taper is cut right into the aluminum. Will this work? Is the aluminum on these old wheels tough enough to do this? I don't want to have to carry special lugs for my spare tire.
Im not hiding. Just been too busy with some stuff thata I cant be as attentive as I would like. Believe that I have had this thought right by my side during the last couple of weeks.
This is what you are looking for, a local company D&B wheels in Ontario, Ca. has them. Circle track racers run these exact inset\rts so you may look in this direction.
The problem with your turbine wheels is that they are not forged wheels run the risk of breaking a wheel if you try to install 8 inserts.
hmmmm
I remember you sayin' something about you were going to put bead locks on your wagon wheels.....
At osme point I was gonna run the DIY beadlock kit, and I ended up buying some already done.
Now, I have had wheels re drilled and had insters presssed in. My current wheels for my crew cab are weld racing wheels only offered in the metric pattern, so I had them fixed so to speak.
I purchased the insters through them but have also purchased them from D&B wheels.
I am not too comfortable about just drilling the wheel and using an acorn style fastener right against the wheel. Having the inster probably provides some sort of added safety factor.
Thank you for sharing your thoughts and knowledge, I know I can count on you and the others here on FTE to put in a solid thought on any of my random questions.
done!
I decided to just keep it simple and run duplex mag lugnuts.
My dad powder coated the wheels clear for me, and my bride and I mounted the tires. That is a lot of work by the way. I used lead shot in the tires to balance them. I really like how well this works. Here is how they turned out.
I was hoping for the magnesium look by going clear, they ended up more grey. I like the look though.
done!
ShowMe-Pickers
1999 to 2016 Super Duty
06-10-2015 01:44 PM
packrat56
09-18-2014 10:52 AM
nikmish
31
11-24-2012 09:00 AM
Buck Super Duty
21
09-20-2010 05:00 PM
Supercab
01-25-2010 12:39 PM
