Resurfacing heads
Old Jul 15, 2009 | 03:08 PM
zachsherman88's Avatar
zachsherman88
Resurfacing heads
im doing some head work and am thinking about resurfacing. If i do what is the best cut for some more compression? im not too worried about having the heads resurfaced for another time after this since i will probably get a different set of aftermarket heads in the future so whatever is the most i can get away with i am curious to know thanks.
Old Jul 15, 2009 | 08:00 PM
mark a.'s Avatar
mark a.
I'd get a set of TMI's pistons if you are looking for more comp. Just milling a set of heads won't get you much + you will have to mill the intake & you will need shorter push rods.
Old Jul 15, 2009 | 08:16 PM
hollenjoe's Avatar
hollenjoe
If your heads havent been milled, you could mill them by 0.030" without having to mill the intake...
Old Jul 16, 2009 | 03:24 AM
johnboy427's Avatar
johnboy427
The heads on my 351C are milled .040. but my machinest milled off the intake side too so a normal intake will work, and yes you will need shorter push rods. With zero deck pistons this got me 9.78:1 which is a pain to work with in a truck that runs on pump gas.
-Johnboy
