towing?
Old Jul 15, 2009 | 01:31 PM
landon460's Avatar
landon460
towing?
My 96 f350 has a low mileage 460, rebuilt C6 tranny, headers, and a cat-back exhaust so I figured it would be good for towing. I guessed wrong. Towing only a 4500lb boat, my truck couldn't keep up to speed going up a hill that was only less than 3 tenths of a mile and at about 7 percent grade. The c6 tranny downshifted and had the motor screaming at the top of the hill at 25m.p.h.(speed limit was 50) in second gear. It has 3.55 gears in it and only 32.6" tires overall. I figured I could go a few inches overstock on the tires and still tow just fine considering I have the 460.
The moral of this story is, I need help. I should be able to tow 12000lbs with it no problem. Hell, I use to tow that much with my stock 78 bronco all the time and it had the same size tires on it and I can't even tow a 4500lb boat with a 460 powered f350! Should I just regear it with 4:11's or try to get more power from the engine. The engine seems really healthy so I don't know. I need some advice.
Old Jul 15, 2009 | 01:55 PM
andym's Avatar
andym
Something is really, really wrong with your truck.
What kind of mileage do you get empty?
What's your base timing set at?
Old Jul 15, 2009 | 04:28 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Yeah, there is something wrong. With a 351, 4.10s, 32s, and a C6 my F250 will hold 45 in second (yeah its reved up) with a 6,000 lb. trailer up a 6-7% grade thats 6 miles long. You should be able to run a lot faster than 25 MPH in second.
Do a full tune up (plugs, wires, cap & rotor, and fuel filter) and pull the codes. At the end of my post is a link to a page that will tell you how to do it without a scanner. Post your results.
http://www.fordfuelinjection.com/?p=13
Old Jul 15, 2009 | 05:30 PM
Beamed's Avatar
Beamed
yea theres somthing wrong buddy i was just pulling a 8,000 pound load yesterday with my f150, 351 4.56s and 37s with 150xxx on the motor and it did great on the highway pulling the grade. id check everything over really good. how old is ur coil?
Old Jul 16, 2009 | 01:15 PM
landon460's Avatar
landon460
I get around 8mpg empty with the 3speed auto. I have never checked the timing considering it has always ran fine. The only thing I can think of is that the computer is reading the o2 sensor wrong because of the exhaust header gasket leak I have. Could this be causing the computer to tell the truck to use more fuel since the reading is wrong?
Old Jul 16, 2009 | 01:33 PM
andym's Avatar
andym
That would account for the bad mileage but not the loss of power. I would really lean towards checking your timing. You need an inductive timing light but it's easy to do.
Old Jul 16, 2009 | 02:08 PM
landon460's Avatar
landon460
Just did a tune up about 200 miles ago. I along with the exhaust leak, Im thinking my power problem might be brakes related. The truck sat for almost 2 years in a very damp garage and when I finally moved it, the right rear brake drum was seized up. I got it to brake loose but ever since I stored it, the truck feels gutless like both rears are dragging. When I push on the gas, it revs up more than it moves and if I push even farther down, about a fith of the way to the floor, I feel a jerk like it the breaks brake loose and then off I go. I think maybe the brakes are still dragging and thats why I don't feel the power like it use to have before sitting.
Do you guys think this could be it? If so, should I adjust them or buy all new drums and internals. Or should I just do a disc brake conversion and how much would that cost?
Old Jul 16, 2009 | 02:10 PM
landon460's Avatar
landon460
[quote=andym;7725983]That would account for the bad mileage but not the loss of power. I would really lean towards checking your timing. You need an inductive timing light but it's easy to do.[/quote
How many degrees should the timing be stock?
Old Jul 16, 2009 | 02:13 PM
andym's Avatar
andym
Originally Posted by landon460
JThe truck sat for almost 2 years in a very damp garage and when I finally moved it, the right rear brake drum was seized up. I got it to brake loose but ever since I stored it, the truck feels gutless like both rears are dragging. When I push on the gas, it revs up more than it moves and if I push even farther down, about a fith of the way to the floor, I feel a jerk like it the breaks brake loose and then off I go.
This would have been good information to share in the original post.
If you think that the brakes are what caused it to be slow towing the boat, then so much heat was generated that it no doubt completely destroyed the rear brakes.
You're going to have to pull the drums off and take a look inside to see what's happening.
Kinda surprised that I have to say this, but towing a boat with a truck that has suspect brakes is really not too smart.
Old Jul 16, 2009 | 02:33 PM
landon460's Avatar
landon460
too smart.
First I would like to thank you for the insult *******. That being said, you don't know the whole story. That was the only time I towed with it since it sat, I only went half a mile, and the brakes might drag but they still stop just as good as they ever have. I don't plan to keep towing with it until I get the problem solved. I have tested to see if the rears are still stopping along with the fronts and they are. They just seem to hang up whenever they feel liket it. I don't drive this truck that often and I know what is smart to do and what is not. People come here to discuss trucks and help others with issues. That can be accomplished without the insults so I suggest you learn to do so.
Old Jul 16, 2009 | 02:36 PM
andym's Avatar
andym
Ok, good luck with you problem then.
Old Jul 16, 2009 | 03:06 PM
No_BS's Avatar
No_BS
Not to sound stupid but if you were topped out in second, going 25, there is a trans issue. Second gear should be like 1.5:1 ish. My T18's 3rd is 1.7:1 ish, and I have smaller (stock) tires, and it will hit 50 at the top of third, 25 is down around 1500-2000 rpm range. Realistically, you should be going faster than me at any given rpm in that gear, beings as it's a taller gear to start with, and you have larger tires. We both have 3.55's. If you were in 1st, ok, but if you were in fact in second there is a problem there.
Old Jul 16, 2009 | 03:16 PM
alxsnmr's Avatar
alxsnmr
landon, andym may have come off a bit brutal, but he is one of the most knowledgeable people on the board who was being blatantly honest with you. I believe the reason for his statement is that if your brakes are already heating up on the rear, you are now overloading the front brakes. Overloading the fronts has the possibility of you jack-knifing the entire set up. Also, sticking brakes could lead to premature failure of your trans, so parking your truck until you get it repaired is much more advisable at this point than the risk with using it.
I can not speak for the rest of the possible boards online for the Ford trucks, but based on hearsay this is one of the better boards, with this thread being one of most honest and least argumentative of the board. But, good luck on resolving the issue and due come back if you have more questions.
Old Jul 16, 2009 | 04:14 PM
landon460's Avatar
landon460
It has been parked since I found out the towing problem. I also had the tranny rebuilt about 6K miles ago so I don't believe its a tranny issue. Im gonna tear the drums down this weekend and take a look.
Old Jul 16, 2009 | 04:26 PM
No_BS's Avatar
No_BS
So you were in first gear then?
