Want to know if these will fit on my 83 f250
looking at buying this guys wheels here is the email he sent me:
"the ones off my truck are bolt pattern 8x 165.1. stud size 14x 1.5 and center bore of either 166.6 or 177 im not sure. its just a standard size for my truck wheel for my truck. i have a 89 chevy k2500."
Will these fit on mytruck if i put coil spacerers on the front. Please let me know anyone...
If they are aftermarket wheels, they should fit with no problems. The wheels on my truck were on a 69 GMC and a 91 3500 before they got to my truck. If they are stock chevy wheels, then the center bore may be an issue. If you have a semi-float rear axle it probably wont matter either way as it's the huge hub protruding from the full float axles that wont go through the wheels.
Okay, well his bolts are 14mm which is a bit under 9/16" honestly i dont know. you being 2wd, you should be good to go but if the center hole is too big ont he rims it wont work very well and you will have speed vibrations, the purpose of the center hole is to center the rim prior to torquing the lug nuts. I would see if you can go over and try it on, i would not buy them blind.
" I dont know what he mean" Hope we get pics soon! Just go try them on, is this a distance deal? I have no idea what he means and where he measured, i dont know if he did it right or if he gives a ****, look bro, sooner or later (sooner) you gotta take matters into your own hands, we can guess all day but frankly "its up to you in the end." I dont know. Go try them on.
The axle flange is 4.75" and the shoulder at the wheel is larger.
For some reason 5.15" keeps coming into my mind for the wheel center bore.
That is just enough bigger than 5.125" that it will not fit.
Guess if you really wanted the wheels, you could have a machine shop turn the center hole a little bigger for you.
The pre 97 wheels are supposed to be lug centric wheels, but the way the stock wheels fit, they are both lug and hub centric.
