Broken spring
Old Nov 4, 2000 | 08:34 PM
Raul's Avatar
Raul
Broken spring
The shift lever on my trans (see below) has been very sloppy and loose for about a month. Today I crawled under the truck. Found that there is a small bracket just to the right (toward passenger side) of where the lever enters the trans. Connected to this bracket is a small spring about 2 1/2 in. long. The other end of the spring obviously connects to the lever to keep it from flopping left and right - the last inch or so of the spring is not coiled like the rest of the spring. What does this end of the spring attach to and how? How much of the spring is gone? Is there a hole in the lever that the spring goes thru? Does it go AROUND the lever? I can find no drawing or description in any of the manuals.
As ever, your advice appreciated. Thanks.
Raul
w/ 81 F-100, I6, SROD, Carter 1V non-feedback carb, no A/C, no PS, no PB, but it gets me where I need to go
Old Jan 24, 2001 | 10:54 AM
Raul's Avatar
Raul
Broken spring
STOP! Please put your pencils down, close your test booklet and pass it to the center isle. This test is finished. :-)
I found the missing part of the spring. The spring has two different coils at opposite ends, one is about 1/4 inch dia. the other about 3/4 inch dia. The small coil goes into the hole in the bracket (already attached) the larger goes around the base of the shifter - it actually goes around the dust boot. I found the most of the larger coil still on the shifter.
Will need to jury-rig as no one lists the spring. But now we all know where it is suppose to go.
Raul
Old Jan 24, 2001 | 10:58 AM
DannyP's Avatar
DannyP
Broken spring
Combining the fact that no one lists the spring and it wraps around the dust boot, I am wondering if someone has already rigged it at some point in the past. Just a thought.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Jan 24, 2001 | 06:33 PM
Eddie's Avatar
Eddie
Broken spring
