5spd to 6spd conversion
Old Aug 22, 2003 | 05:09 PM
StrangeRanger's Avatar
StrangeRanger
The 6 speed is a ZF S6-650. It too has an integral bell housing
Old Aug 25, 2003 | 05:33 PM
nogo73's Avatar
nogo73
so I have an adapter on my tranny?
Old Aug 25, 2003 | 11:11 PM
archangel's Avatar
archangel
Actually it adapts the trans bell housing to the diesel block as the block is (I assume) designed for industrial applications, but they should have made it in the 460 bolt pattern, unless they didn't want them to swap out for possible compatibility issues like stall speed and governed shifting speed.
Old Aug 26, 2003 | 11:55 PM
troposcatter's Avatar
troposcatter
Yeah I,ve seen them on the bigger diesels,if I'm thinking the same thing, a lot of them use the same bell housings, instead of having a "flange" cast onto the back of the engine with different bolt patterns such as GMs "bow tie" Fords BB,SB FE etc you can make and bolt whatever you want on the back of the engine.
Old Jun 23, 2007 | 02:21 AM
fordswap's Avatar
fordswap
Can the 6spd handle a 5.9 cummins? And is it only good for 650ft of torque? Is there something better?
countrylove
1983 - 2012 Ranger & B-Series
Feb 25, 2017 12:00 PM
fast65back1
16
Sep 20, 2015 09:24 PM
69issofine
Mar 31, 2015 10:08 PM
6t6merc
Jan 26, 2010 03:53 AM
elsmith
Jul 15, 2001 10:59 PM
