still confused
Old Jul 14, 2009 | 12:40 AM
dragonmaster093's Avatar
dragonmaster093
still confused
ok i ot an 86 f150 efi 5.0 w/dual tanks front tank causes all sorts of stumbling to the point itll almost die switch from front to rear and back itll sort of come back still will stumble run rear tank stumbles but not as bad any ideas??? does each tank have seperate fuel pump? could it be the valve for switching the tanks???? fuel filter looks relativly new (seen it looking down from under hood on drivers side frame rail)
Old Jul 14, 2009 | 12:55 AM
hilgerbeast's Avatar
hilgerbeast
is there crap in your tanks?
Old Jul 14, 2009 | 12:57 AM
dragonmaster093
also has i beleive overloads has one set of springs what looks to be aspacer then another set when you go over bumps the upper set hits the brackets on frame and clanks not big issue just annoying is there any rubbers or anything for them?
Old Jul 14, 2009 | 12:58 AM
dragonmaster093
idk have only had it for 16 days
Old Jul 14, 2009 | 07:02 AM
uncle.stosh's Avatar
uncle.stosh
Yes, there are supposed to be rubber isolators on those brackets.
If you are hitting the overload springs by simply going over a bump, then your main spring pack is shot and sagging.
They only come into play when you have a heavy load in the bed.
Old Jul 14, 2009 | 01:59 PM
86bigred's Avatar
86bigred
there is a pump in each tank and i believe one in the frame.since you have only had the truck a short time is the tank your having trouble with have good fuel in it or stale fuel?that could be the problem. fuel can start to go stale in as little as 30 days(i have never seen this).but when did the po last put fuel in that tank?
Old Jul 14, 2009 | 03:09 PM
dragonmaster093
filled it on the day i got it and back one 3 days later
Old Jul 15, 2009 | 07:54 PM
86bigred's Avatar
86bigred
can you pull the codes off the computer.might be fuel pressure regulator.
