Coil and sluggish
Old Dec 18, 2002 | 07:53 PM
fredbear891's Avatar
fredbear891
Coil and sluggish
[updated:LAST EDITED ON 18-Dec-02 AT 08:55 PM (EST)]Ok had a sluggish 2000 expedition last week. Engine light comes on. Tested and said #4 coil bad. Replaced coil and now I still have the sluggish drive. Like the truck is missing. This happens at all speeds and worse when it is cold. If I have a coil go bad should I also change plugs, etc. Any help would be greatly appreciated. 2000 Expedition 4.6l has 70,500 miles on it.
Thanks
Mike
Old Dec 18, 2002 | 10:31 PM
charlesvalentine's Avatar
charlesvalentine
Coil and sluggish
Is the MIL still on? The #4 coil going out is a common problem. Have you tested for additional codes? Have you tried pulling the power/battery cable for a few minutes to reset everything?
99 F250SD EC 5.4L 3.73 285 BFG/ATs...
99 Expy EB 5.4L
Old Dec 19, 2002 | 07:42 AM
fredbear891
Coil and sluggish
I am still new to this stuff. My check engine light went off when the coil was replaced. If I remove the battery cable will I lose all my alarm stuff, keys to start, etc because I only have one key for this car and do not want to lose the ability to start it
Mike
Old Dec 19, 2002 | 11:22 AM
charlesvalentine
Coil and sluggish
Hmm. Your alarm I have no idea about. But I have pulled the battery numerous times and never had to reprogram the Ford chipped key. It sounds like you had someone else do the repair? I would definitely bring it back and tell them you are still having the prob.
99 Expy EB 5.4L
Old Dec 19, 2002 | 12:53 PM
fredbear891
Coil and sluggish
It is going back to the shop today
I will keep you posted on this
Thanks for the help
Mike
Old Jan 2, 2003 | 08:18 PM
fredbear891
Coil and sluggish
expy went back to shop. Had a hairline crack in the #2 spark plug. Changed plug all is fine now. Also the #4 coil was replaced.
Thanks for all the help
Mike
Old Jan 2, 2003 | 08:47 PM
Racerguy's Avatar
Racerguy
Coil and sluggish
eurokie
Escape & Escape Hybrid
Oct 1, 2013 10:32 PM
gtadim
Aug 12, 2013 10:24 PM
rockstarf150
1997 - 2003 F150
Jul 9, 2012 10:53 PM
xtmsports
Sep 10, 2010 06:05 PM
shanempickle
Sep 14, 2008 11:18 AM
