Intake Manifold Lines
Old Jul 13, 2009 | 08:03 PM
Holiver31's Avatar
Holiver31
Was changin out the fuel filter today, when I took it off I noticed a line directly under the filter that had been cut off. I had never noticed it before since the filter was in the way. What is this, where should it go, do I need it? I'll post a pic if necessary.
Old Jul 13, 2009 | 08:13 PM
77f2504by4's Avatar
77f2504by4
please post a picture...
Old Jul 13, 2009 | 08:24 PM
Holiver31's Avatar
Holiver31
last one is a hole i found that is threaded.
Old Jul 13, 2009 | 08:29 PM
fmc400's Avatar
fmc400
MSEE
Replace the short length of hose with a vacuum cap; it needs to be plugged. I find it odd that there is reside around it, however. What motor is this?
Old Jul 13, 2009 | 08:53 PM
Holiver31's Avatar
Holiver31
I should have posted that sorry, 1977 F150 400 C6 2WD. What did it use to hook up to? And what's with the empty threaded hole?
Old Jul 13, 2009 | 09:00 PM
fmc400's Avatar
fmc400
MSEE
400 would be a dry manifold, so a vacuum tap is the only thing it could be. It's hard to say what it would have gone too; looks like a quarter inch ID so I would guess transmission modulator or heater controls maybe. The threaded hole is a mounting boss to mount an accessory bracket.
Old Jul 13, 2009 | 09:10 PM
Holiver31's Avatar
Holiver31
Well the heat works, are there any bad effects that it could cause not having it hooked?
Old Jul 13, 2009 | 09:18 PM
fmc400's Avatar
fmc400
MSEE
I can't really answer that without knowing what vacuum accessories are missing from your truck, if any. A lot of times those came from the factory plugged; a previous owner probably put the hose there for some unknown reason. If you're not having any problems, just plug it and you should be fine.
Old Jul 13, 2009 | 09:23 PM
Holiver31's Avatar
Holiver31
Sounds great, thanks alot fmc
Old Jul 14, 2009 | 12:10 AM
Jermafenser's Avatar
Jermafenser
Start the truck and put a finger over that hose. If you feel sucking, it's the front manifold vacuum source.
Some emissions calibrations use the front manifold vacuum source, some don't. That's why you see some with a nipple, some without. Mine has a nipple as my emissions diagram shows it was used for the vacuum reservoir by the main battery tray.
Since my vacuum routing is FUBAR, that hole was plugged with a vacuum cap. I use that source to hook up my vacuum gauge for diagnosing.
Old Jul 14, 2009 | 12:55 AM
Holiver31's Avatar
Holiver31
I couldn't feel any vacume, there could be a possibilty it's plugged though right? I'll pull it tommorow and see if there is any vacume. Can I just pick up a plug at Autozone or something?
Old Jul 14, 2009 | 08:20 AM
fmc400's Avatar
fmc400
MSEE
Yes and yes.
Old Jul 14, 2009 | 11:14 AM
Jermafenser
From what I've seen, many mud wasps build nests in it.
You can even use a bolt. But I'd just use a vacuum cap, so you can have easy access for a vacuum gauge whenever you need it.
Old Jul 14, 2009 | 12:18 PM
Holiver31's Avatar
Holiver31
Thanks Jerm and fmc, I'd rep you but it says I need to pass it around.
