thru the floor brake pedal arm measurements, 53-55
apparently when I stripped the 54 before blasting 2 yrs ago, I tossed the whole brake pedal/master assembly.
we are using a chevy version from TCI on our custom chassis to minimize the length of the assembly.. (the MF bracket makes the whole arm/booster/master length about 26 inches!)
can someone tell me how long the brake pedal arm is from pivot to turn
and from turn to brake pedal pad,
thanks..
sam
thanks..
sam
Ok, I'm back. I measured, from the center of the pivot, to the first radius, 5". From the first radius to the radius right outside the toe-board, 9.5". From the radius right outside the toe-board, to the pedal, 8". I didn't measure the little bend where the arm hits the pedal stop bumper, I just measures in straight lengths: pivot to raidus, radius to radius, radius to pedal mount spot. The clutch pedal, and brake pedal are different, at the pivot mounting end, but the bends, and measurements should be good for what you need.
remounted the cab to the chassis this morning, and looks like I only need a little unbend of the first turn to make it work.. crap, ran out of oxy!.. SO, it'll have to wait for a trip to town again..
how much clearance is there between the arm and the cab with no pressure on the pedal? 1/2 to 1 in?
sam
sam
milehieagle
01-01-2015 10:05 AM
Drac
05-16-2013 09:03 AM
oldblu
12-31-2011 01:28 PM
Idaho Mtn Man
17
03-13-2011 11:51 AM
73FOMO
11-13-2005 01:04 PM
