Another 5.4 difference question
Old Jul 13, 2009 | 01:10 AM
Superdave's Avatar
Superdave
So as not to highjack the post below, I have another 5.4 question.
I came across what was to be, a good running short block 5.4 from a 2000, F-150 Lightning.
It was in the high 60,000 mile range. Owner has bought a crazy built, 5.4 long block, for more power.
Would this short block work as a starting point in my 2000 Superduty, with the 5.4. Or is the SVT engine a different breed modular engine all together?
Owner says it has a steel crank and stronger pistons? Thought I may grab onto it for future use. From what I'm reading on here about these peach 5.4's, I'll probably need it.
thanks
Old Jul 13, 2009 | 06:06 AM
torkum's Avatar
torkum
Sounds like a good deal and yes it will work. Best part is the forged crank.
Old Jul 14, 2009 | 02:44 AM
Superdave's Avatar
Superdave
It would be the same compression ratio also?
Old Jul 14, 2009 | 06:11 AM
torkum's Avatar
torkum
The compression ratio on the Lightning block is 8.4:1 and on the standard 5.4 block is 9.30:1 You will want to get a tuner to adjust for the difference along with any other mods you make.
Old Jul 14, 2009 | 03:47 PM
Superdave's Avatar
Superdave
I got to thinking about the compression ratio possibly being lower, since that is a supercharged engine.
Thanks
Luckett35
Modular V8 (4.6L, 5.4L)
Jul 28, 2016 05:36 PM
scev
Jul 10, 2016 10:42 PM
Mechanic special
Nov 26, 2015 04:33 PM
wade8422
1997 - 2003 F150
Nov 27, 2012 07:30 PM
wall77
Nov 12, 2009 07:36 AM
