Engine rattle
Old Jul 12, 2009 | 11:17 PM
camekanix's Avatar
camekanix
Engine rattle
Hi all,
My 85 Bronco has at 351w, C-6 powertrain and I am getting a strange noise at steady highway speeds with light throttle. It is a rattle that can be heard loud and clear under light steady throttle. if you let off or accelerate it goes away I thought it was the timing chain being loose that was causing this so I replaced it and the cover. the cover has a rub mark in it because the chain was that loose. The new chain and gears are much tighter but after I got it back together it still makes the noise. Any Ideas?
Thanks in advance for any advice
Old Jul 12, 2009 | 11:52 PM
86bigred's Avatar
86bigred
sounds like detonation.is your bronco efi or carb.if it's carb your power valve could be shot.if it's efi pull the codes.
Old Jul 13, 2009 | 09:55 AM
clgreer's Avatar
clgreer
agree, sounds like detonation to me as well
Old Jul 19, 2009 | 06:30 PM
camekanix's Avatar
camekanix
I appreciate the advice but it really seems more mechanical than that. Any time I've heard detonation it has been a random rattle. This is a very consistenr noise that perfectly matches engine speed at steady load above 50 MPH. any big changes in throttle ( on or off ) and it goes away. It is too high to be bottom end and too deep to be lifter noise. Ambient temp makes no difference either, summer or winter and it still does it. I am at a loss. Again, I appreciate any input and can not say detonation is not it for sure. It just seems too consistent for that. Thanks again.
Old Jul 21, 2009 | 08:14 AM
Freaksh0w's Avatar
Freaksh0w
Could be an exhaust leak. Look around the manifolds for any black spots where a leak could be. I have one tiny leak on mine, and it made the same consistent rattle you speak of. Annoying.
Old Jul 23, 2009 | 11:37 AM
86bigred's Avatar
86bigred
on my ranger one cylinder went lean and it rattled so bad i thought a rod had gone bad.you said it will rattle at various rpms but when you floor it it goes away.when you floor it your accelerator pump dumps raw fuel into the intake,thus richening up the a/f ratio causing it to stop rattling.
Old Jul 28, 2009 | 06:39 PM
camekanix's Avatar
camekanix
It also goes away when I ease up a bit on throttle too. I found a new symptom today though. If I floor it the noise starts at about 3000 rpm and gets louder with increased rpm. It is very consistent with engine speed too. after doing this it has developed a momentary hesitation on moderate to hard acceleration. It's like the ignition cuts out for a split second then everything is fine. I can hear the hesitation through the carb too. It is not backfiring, just a slight poof noise once in a while on acceleration. I'll be checking plugs this weekend in case I have a lean hole though.
Old Jul 28, 2009 | 08:42 PM
Beanscoot's Avatar
Beanscoot
Piston slap?
Try to recreate the noise with the vehicle stopped, hood open and working the throttle by hand.
Old Jul 29, 2009 | 10:57 AM
TigerDan's Avatar
TigerDan
As Beanscoot said, will it make the noise at idle or under a no-load condition, such as when you free rev the engine? Try running it up to 3 grand or so while sitting and hold it there and see if it does it, if so, then vary engine speed as you described above to see if it will still lessen or go away under acceleration/deceleration.
If you can simulate the condition while sitting, try pulling a plug wire one at a time and see if you can isolate it to one particular cylinder. If you kill a cylinder and the noise goes away, then you can tell it's caused by that cylinder. I'm sort of thinking wrist pin knock here...
phillycincykid
Jan 22, 2017 01:21 PM
jeffg2500
Aug 21, 2015 10:40 AM
matttrox
2004 - 2008 F150
Apr 20, 2015 08:06 PM
meborder
Modular V8 (4.6L, 5.4L)
Sep 17, 2014 12:30 AM
DMC12
2004 - 2008 F150
Aug 9, 2014 05:34 PM
