Instrument Panel
Old Jul 12, 2009 | 06:55 PM
Forester714's Avatar
Forester714
Instrument Panel
Greetings Everyone,
Looking for some input here, drove my truck, 2002 F-350 Diesel 7.3 powerstroke, down my driveway all was fine, stop started it backup and no instrument panel gauges work, the accelerator pedal does not work truck starts and idles fine, radio and clock work. Checked all fuses that relate to instrument panel, 4x4, fuse were good. Does anybody have any input as to what be going on here.
Thank you
Old Jul 12, 2009 | 08:17 PM
Oversize's Avatar
Oversize
Id start with you TRS if its out of adjustment it wont set the gear or the sensors for it. Also Im afraid your in the wrong forum here this for the 94.5-97 diesels the moderator should be able to move you to the right forum. Good luck. Welcome to FTE.
Old Jul 12, 2009 | 09:18 PM
RubberDuck's Avatar
RubberDuck
Forester, Welcome to FTE. You have come "almost" to the right place. This is the Old Body Style section 94.5-97 Powerstrokes. Your section is one forum above us.
However, I have your answer, so I'll hook ya up.
The problem is a 3 wire cluster under your steering column cover. This is a very common problem on the superdutys. Take the plastic cover off the column. Should be a couple of screws from the bottom side. Once that's off, you will see a secton of wire running from the left side over the top of the column. It's got three wires in it. Inspect these real carefully. You will most likely find a spot where they got chaifed and shorted. Just cut, splice, heat shrink it, or worst case, electrical tape it up. Either way, you know what you need to do from there. Then some small wire loom covering should prevent it from happening again.
Hope that helps man.
Mikhail
6.4L Power Stroke Diesel
Oct 11, 2012 12:47 PM
mdg100
Oct 22, 2009 04:03 PM
droop55
Aug 11, 2007 11:34 PM
jdakin1
Jan 11, 2006 11:25 PM
DWalker
Feb 28, 2002 02:38 PM
