General Automotive Discussion
Sunfire wont start
Old Jul 10, 2009 | 04:13 PM
meanv10's Avatar
meanv10
Sunfire wont start
A week ago the battery light came on while driving.
two days latter the car wont start.
I pulled the starter and the battery and got them tested at autozone
batteries is bad and the starter is fine.
put the starter back in and hooked the car up to a deep cycle marine battery. the whole car has power but when the key is all the way forward nothing happens. so I jumpered the solenoid and the car turns over but when the key is all the way forward there is no power to the solenoid
any Ideas?
and she just bought an escape ( thats being talked about in the escape forum)
Old Jul 10, 2009 | 05:26 PM
jim henderson's Avatar
jim henderson
make sure the battery connections are clean and tight. that can prevent even a good battery from turning the engine. Sometimes the terminals will get a kind of shiney dark coating. That seems to act like an insulator and keep power from flowing enough to start.
Also, I am not sure if a deep cycle battery has enough cranking amps to do the job, never tried that. They are usually made to supply a good steady current for a long time, not a heavy current for a quick start. I could be wrong here tho. Some are deep cycle and start so might work better.
Clean the terminals etc and see what happens. If still no start, try a jumper cable. If a jumper works that would make me think the battery doesn't have enough cranking power.
Good Luck,
Jim Henderson
Old Jul 10, 2009 | 07:21 PM
Ford_Six's Avatar
Ford_Six
Battery light on = no charge, hence the no start after a few days. Dumb question to ask, but is the car in park or neutral, or is the clutch being pushed down? Are you using the proper anti-theft key?
Old Jul 11, 2009 | 11:12 AM
meanv10's Avatar
meanv10
yes the car is in park, I tried neutral also ( its an automatic)
If I jumper the solenoid with 2 screw drivers it turns over.
Old Jul 11, 2009 | 11:36 AM
Ford_Six's Avatar
Ford_Six
Are you sure you have the wires in the right spots on the starter? IIRC, there are four terminals- The big one from the battery, the other big one out to the starter, a small one that activates the solenoid, and a fourth one that sends power out to the fuel pump while cranking. I think if you reverse the two small leads, it won't operate the solenoid.
After you check that, if it still doesn't work, then check for voltage while someone turns the key to the start position. If there is full battery voltage, and the leads are all to the correct terminals, then the solenoid is indeed faulty. If there isn't power, you'll need to keep working upstream on the start circuit until you find the issue.
FWIW, it could be a failed P/N safety switch. It may not be making contact.
Old Jul 13, 2009 | 04:11 PM
meanv10's Avatar
meanv10
I checked for voltage while it was turned so it would crank over. there was nothing, so it has to be a wiring problem, were? i dont know and what do you mean by failed PN safty switch?
Old Jul 15, 2009 | 10:04 PM
Ford_Six's Avatar
Ford_Six
The switch that tells it it's in park or neutral, allowing it to start-
margobin
Escape & Escape Hybrid
Oct 15, 2012 05:04 PM
drewduncan15
Aug 4, 2012 11:14 AM
nathanbetty9507
Oct 18, 2011 02:56 PM
69mustang
Aug 2, 2004 03:42 PM
JasoninOR
Sep 18, 2003 06:29 PM
