[font size="1" color="#FF0000"]LAST EDITED ON 15-Apr-01 AT 08:25 PM (EST)[/font][p]Ok I have a 1969 F250 with a C6 trans. I would like to put in a AOD trans. Any idea's on where or what I should look for?
Oh yea it is a 390cid with a 4.10 rear gears. I don't want to change the rear gears.
Thanks
My Truck
http://www.radarscastle.com/MyTruck/index.htm
Unfortunately, you have no chance of adapting an AOD in there...
The C-6 is available in 3, yes 3 bolt patterns.
1 - 289,300,302,351W - 335 Series Small Blocks
2 - 360,390,410,428 - FE Series Big Blocks
3 - 351M,400,429,460 - 385 Series Big Blocks
Unfortunately the AOD/E4OD are made for late model Ford engines(335/385 series), never for the older FE's. You would have to go with an over/under drive unit or goto a manual tranny.
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks....
US Gear and Gear Vendors offer over drive units that go after the trans to add additional gears. The cost is about $2500~$3000 and usually requires a new custom drive line and most use electric shifter buttons. If you want lower hiway rpm, your best bet is a gear change or taller tires, it's not a great option but it's the cheapest. If you do the gear change yourself, you could pay <$200 and save the old gears then change back later if you don't like it.
Some have adapted a 2speed 4x4 transfer case and change the gears so that they have a low range for climbing and a high range for hiway use, and you can buy a NP205 for cheap, but you'd spend some time making mounts and rigging everything up. The NP205 has a 1:1 and 2:1 so that would give you a really low range compared to stock.
