E4OD noise
Old Apr 7, 2001 | 03:48 PM
jwdenney1's Avatar
jwdenney1
E4OD noise
I have a 1990 F150 w/E4OD and 351 CI engine. At higher RPM's, there is a kind of rattling in the transmission. This is usually over 3000 RPM, but it almost sounds like there is loose metal inside the tranny or something. It doesn't do it at lower RPM's at all. Any help is appreciated.
John
jwdenney(No Email Addresses In Posts!)
jwdenney@prodigy.net
Old Apr 16, 2001 | 09:21 PM
capt scott's Avatar
capt scott
E4OD noise
good luck with the e4od. i have an 89 f350 with the diesel and the e4od. i am on my 3rd tranny. this last one has less than 1000 miles and already it is making whining noises from the pump and makes a noise similar to what you are describing. my noise happens when i am towing my boat, going down the road and trying to maintain steady speed...not pulling and not coasting. when i mash the fuel it quits. when i let completely off the fuel, it still makes the noise but not quite as bad. not pulling the boat, it is barely noticable. this last unit was over $2k and was a remanned unit from ford. do you or anyone have any ideas before i have them install another unit?
thanks for the ear.
scott
Old Apr 17, 2001 | 06:28 AM
jwdenney's Avatar
jwdenney
E4OD noise
For that F350, a shift kit and high capacity pump maybe. Also, the best torque converter you can buy. Good luck.
Old Apr 17, 2001 | 08:56 AM
dave89f150's Avatar
dave89f150
E4OD noise
jwdenney2
2004 - 2008 F150
Dec 23, 2015 01:15 AM
blaze 57
Jun 25, 2015 03:36 PM
jwdenney2
2004 - 2008 F150
39
Jun 23, 2015 06:19 AM
RIKIL
May 25, 2012 12:56 AM
jwdenney2
2004 - 2008 F150
38
Jun 22, 2009 07:28 PM
