I use different oil brands on a regular basis. I also switch between a full synthetic and a synth blend depending on the season. No problems, no worries.
i use Havoline and i was wondering if i changed to another brand of oil would my motor start using oil?
Your using a mighty good product & a good value, so why change brands????
Anyway, the guys are right changing brands to the same specified weight & service grade, isn't likely to cause consumption problems, unless the brand changed too has a greater high temp % evaporation (NOAC) & you operate at high ambient temps, for long periods, like long, hot, high speed highway runs, while towing, hauling, or operating the A/C around town in hot stop & go driving for extended periods.
