Charging Problems - 1989 F-150
While on a trip, I noticed the voltmeter in the dash drop to around 12 or so volts from the usual 14ish. A week later the battery was dead, it was 6 yrs. old so I bought a new one. Of course the next morning the truck wouldn't start, dead battery. I then charged the battery up over night. The next morning I started the truck, with the motor running, I have 12.8 volts across the battery posts. Measuring from the positive termanal to a ground on the motor or frame, I get the same voltage. With the motor off I have about 12.5 volts. I have 2 plugs on the alternator, I've removed them, blew them out with air and applied dia-electric paste. No change. It's only been less than 1 day since the over- night charge, but I'm sure the low voltage is a problem. Thanks in advance.
If you have the 2G alternator one of the plugs on the back may have shorted internally draining the battery overnight.
At least it has happened to me.
They make an aftermarket replacement alternator pigtail that any well stocked auto parts store should have. You cut the old one off and attach the new plug.
I finally got sick of trying to burn down my truck and swapped to a later 3G alternator using one of Ryan's harnesses from fordfuelinjection.com
That is, if it discharges w/ the alternator unplugged.
Otherwise it could be the alternator, but the simple check is to unplug the alternator and see if there's measurable voltage drop overnight.
See this thread: https://www.ford-trucks.com/forums/3...st-burned.html
If you have 12.8 volts with the alternator running, either you have a bad connection to the alternator, or it is broken. Running voltage should be close to 14.
Check the green with red stripe wire coming to the alternator. With the ignition on, it should supply 12 volts. This turns the alternator on. Check both ends of all the connections, including the plugs. Look for corrosion, or melted plug. The next step is pull it for a bench test at about any parts place. Since the battery discharged overnight, I would suspect a bad diode inside the alternator, but usually a bad diode will still let it have the correct output.
If the alternator is bad, you can replace it and splice in a new plug, or upgrade to a 3G. The 3G doesn't use a plastic plug, and can produce a lot more amps than the 2G. Nearly everything you need is available in a upull junkyard for a few dollars.
Read some of the old threads about this upgrade, and be sure and use a fuse. Big potential for a fire with the old stock 2G or an improperly wired 3G that doesn't include a fuse. Couple of years ago a local lady burned down her house when her 2G alternator set the truck on fire in the attached garage.
Good luck Frank
Good luck Frank
the small gauge green wire reads the small as battery voltage when switched on. the voltage is actually 11.5. I can't explain that, except that meter may be crap, it's a new digital one though. the larger plug does show signs of melting. I'll go replace that now if I can find one, I"ll check autozone and the junkyard. It's not clear if a auto parts alternator check will answer all the questions. I'll try to find a $15 pick and pull ford alternator and try that. I don't trust the $100 auto parts store alternators..........
thanks for all the help so far.
