Brake controller
Old Jul 9, 2009 | 04:32 PM
jmmartin's Avatar
jmmartin
Brake controller
How bad is it to install a brake controller? i have a 30' 5-er to haul saturday. Lots of hills, want the extra protection of trailer brakes...
Old Jul 9, 2009 | 08:57 PM
JesterPgh's Avatar
JesterPgh
Haven't done one in awhile, but they're not bad if I recall. If you have one already, follow the in-box instructions, if you're going to buy one, follow the included instructions. I think the last one I did I had done in 20 minutes. Sorry I can't be more help than that, but they really aren't that bad, especially if you are even slightly mechanically inclined.
Old Jul 9, 2009 | 10:18 PM
jmmartin's Avatar
jmmartin
mechanically, slightly, electrically, very. hopefully the two togather will help...
Old Jul 9, 2009 | 10:58 PM
JesterPgh's Avatar
JesterPgh
Yeah, you'll be good to go. They are relatively simple, and I'm NOT very electrically inclined.
Old Jul 9, 2009 | 11:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle
It takes longer to run the wires back to and install the 7 blade trailer connector than it does to install the controller.
Brake light signal from the switch on the pedal.
Power to the unit.
Power to the trailer connector from the controller.
And a ground wire.
If the trailer has a breakaway battery, you also need battery power in the connector to charge the breakaway battery.
Also in my opinion, if you want reliable brakes everytime, run a ground wire back up to the battery negative terminal instead of relying on a frame ground connection or grounding through the ball.
Old Jul 10, 2009 | 03:34 PM
jmmartin's Avatar
jmmartin
already have the 7way. but that is a good idea about the dedicated ground. gonna have to do that. planning on running a dedicated hot to the plug, will run a ground while i am at it... thankz dave
Old Jul 10, 2009 | 04:24 PM
jmmartin's Avatar
jmmartin
ok this sob is ticking me off. one line of the instructions says to hook it into the turn switch b/c if you hook it into the stop switch you can ruin the stop switch... the next line says hook it to the stop switch... WHICH IS IT!!!!!! MY HAIR IS ALREADY TURNING GREY TO EARLY AS IT IS!!!!!!!!! lol
Old Jul 10, 2009 | 05:16 PM
Dave Sponaugle
If you hook it to the turn signal, every time you turn the signal on the brakes will pulse with the flasher.
Mine is hooked to the brake light switch under the dash.
Just make sure you are on the wire out, not the power going to the brake light switch.
Test light or multimeter to make sure your wire only has power when the pedal is depressed.
