Dana 60 Differential Identification?
Old Jul 9, 2009 | 04:27 PM
highboy1979's Avatar
highboy1979
I just bought a dana 60 rear axle and im not sure what kind of gear ratio it has or what kind of differential it is. I have the axle tag numbers if anyone can help me out.... (4 10 D8TA SB 603901-4 L S) Thanks...
Old Jul 9, 2009 | 04:44 PM
montana_highboy's Avatar
montana_highboy
4.10's limited slip
Old Jul 9, 2009 | 04:51 PM
highboy1979
Thanks alot bud...
Old Jul 9, 2009 | 05:13 PM
75F350's Avatar
75F350
Shouldn't the tag say, 4L10 if it had a LS unit?
Any bets that its open?
Pull the cover man. Look at it and see. If the axle is out of the truck, you can roll the axle and remove the cover in about 5 minutes without dropping a bit of oil. Then you can tighten the cover back up and you will know for sure.
Ive never trusted the tag. These old axles have the potential to have anything in them and still have the original tag. Oddly enough I have seen tags on used axles that were installed to give the appearance of something that not quite accurate. Unfortunately it happens.
Though I have never purchased an axle without inspecting the ring and pinion, I have seen several tags that had lies written all over it.
Old Jul 10, 2009 | 12:45 PM
ChaseTruck754's Avatar
ChaseTruck754
yeah - 4 10....... = open carrier and 4L10........ = limited slip
You never know with a truck this old though. A previous owner could have changed gear ratio in it. Best bet is to pull the diff cover and check
augsburger
Oct 30, 2016 10:20 AM
Ace!
May 7, 2016 11:59 PM
3KIDDAD
Sep 17, 2012 07:03 PM
vettman
Aug 1, 2011 06:52 AM
Vijay
24
Oct 19, 2009 01:54 PM
