cross member?
Old Jul 9, 2009 | 03:06 PM
willis1991's Avatar
willis1991
cross member?
ok i have been building a 1979 ford f-150 ranger from the ground up i have a 460 suped up idk what all is in it and a C6 Race tranny i need to know if it would hurt the frame if i run it without the cross member that goes under the bell housing i have been having troubles lining it back up sence i got the new tranny in underneith the truck so any hints or anything would be extreamly helpfull
Old Jul 9, 2009 | 03:13 PM
bigdavesohc's Avatar
bigdavesohc
I might cut and weld it, but I sure wouldn't remove it...
Welcome to FTE
Old Jul 9, 2009 | 03:16 PM
willis1991's Avatar
willis1991
ok thank you
Old Jul 9, 2009 | 04:47 PM
75F350's Avatar
75F350
Lets try to talk about why the crossmember does not fit anymore? I'm an advocate for fabrication, but in this case, it sounds as though something is just not square, and attention should be paid to the real problem, and this real problem is what is preventing this x-member from lining up.
Whats crooked and preventing this from bolting in?
Old Jul 10, 2009 | 01:19 PM
ChaseTruck754's Avatar
ChaseTruck754
Are we talknig the tranny mount x-member or the x-member under the bellhousing of the tranny?
I think the one under the bellhousing. If willis moved the motor back or down in his build this x-member would come on contact with the bellhousing pretty easy. My bellhousing on my NV4500 almost rests on the cx-member. In fact I can't pull the tranny with the motor in the truck after my swap. I will therefore be grinding out the rivets from that x-member and changing them out for bolts so I can take the x-member out to then drop the trans.
Old Jul 10, 2009 | 02:10 PM
hp246's Avatar
hp246
Any chance that crossmember took a hit? I had to repace mine cause it looked like someone ran over a fence post with it. after I removed it during the rebuild, it would not go back in. A replacement went in just fine.
Old Jul 10, 2009 | 03:04 PM
bigdavesohc
Chasetruck, what motor do you have the NV4500 connected to?
...please say FE...
Old Jul 10, 2009 | 04:15 PM
willis1991's Avatar
willis1991
the crossmember was bent i straightened it out and it fit like it was suppose to.
Old Jul 10, 2009 | 04:36 PM
ChaseTruck754
...please say FE...
Why the hell would I want a gas guzzling, underpowered FE?????? Hahahaha - let the flaming begin!
And no - I don't have a bowtie in it either. I have a REAL motor...
Cummins 5.9l 6bta
Old Jul 10, 2009 | 04:47 PM
willis1991's Avatar
willis1991
oh wow that is kick *** how does it run?
Old Jul 10, 2009 | 05:25 PM
ChaseTruck754
It doesn't yet - hahaha
https://www.ford-trucks.com/forums/7...ml#post7703657
The 91 dodge I had with the cummins that I bought to be the original motor donor was pretty sweet though
Old Jul 10, 2009 | 11:37 PM
hp246's Avatar
hp246
Willis1991,
Sounds like you disassembled everything (like I did). Mine fit, until I took it apart, then started reassembly after blasting and painting. I think that when you pull that crossmember, it allows the frame to truly return to its original dimensions. You should be able to find a good crossmember. I think I got mine for around $30. It fit like a glove (not the OJ type). The one that had been damaged and repaired wouldn't fit.
Old Jul 13, 2009 | 10:47 AM
willis1991's Avatar
willis1991
i got myn to fit back in finaly after heating it up with a torch and bending ita lil and beating on it it was only about a quarter of a inch off from fiting so i finaly got it to go in.
idtoy
Aug 6, 2012 05:24 PM
Ford F834
Mar 18, 2012 11:31 PM
mbolte
Mar 12, 2010 05:11 PM
Duke58f100
Jun 8, 2008 05:28 PM
chrono4
Offroad & 4x4
Mar 14, 2006 10:04 PM
