'97 expedition
Old Jul 9, 2009 | 11:50 AM
tridge's Avatar
tridge
'97 expedition
how hard to replace shifter cable from stearing to trans , very stiff to put into gear , tried to lube already
Old Jul 9, 2009 | 09:53 PM
nistech414's Avatar
nistech414
Could be the range selector on the side of the trans, aka nuetral safety switch. Sometimes a little scale builds between the selector shaft and the plastic of the switch causing it to bind. Remove the cable from the switch and see if the cable moves freely. If so then the switch could be the problem.
Old Jul 10, 2009 | 04:41 AM
tridge's Avatar
tridge
Thanks , will try over w/e
Old Jul 16, 2009 | 07:44 AM
nistech414's Avatar
nistech414
Any luck with this tridge?
Old Aug 16, 2009 | 05:30 PM
madsonp's Avatar
madsonp
Today my wife's complained that her expy was getting difficult to shift. I put it up on the lift today and discovered an accumulation of gravel by the shift linkage/switch on the transmission (we live on a gravel rode). Once I got the rocks cleared out of the way it worked fine again.
Old Aug 16, 2009 | 08:20 PM
TexFinn's Avatar
TexFinn
I changed the shifter cable on my old 00 EB in probably less than 30 minutes from start to finish a few years ago. Very easy.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
