Steering stabilizer recommendations
Old Jul 8, 2009 | 10:08 PM
stuntmedic's Avatar
stuntmedic
Need to replace my factory steering stabilizer and wondered which brand is recommended. Are aftermarkets (Rancho, Skyjacker etc.) worth the extra money or are OEM good enough. My Ex is a 2004, V8, 4x4.
Thanks
Old Jul 9, 2009 | 12:26 AM
YellowSled's Avatar
YellowSled
pictures posted in this thread.. https://www.ford-trucks.com/forums/8...ims-tires.html
I put in rough country dual kit. I can really feel aa diffrence over the stock one.
Old Jul 21, 2009 | 01:43 PM
chawkjr's Avatar
chawkjr
that model # is for a ford truck it show another part# for the ex. whats the reason for this this is on the lift kit
Old Jul 21, 2009 | 01:51 PM
YellowSled's Avatar
YellowSled
i dont remember the part #. I thought the kit would be the same for all 99-04 super duty trucks.
Reason: firms up the steering and helps offroading when you bump a rock or something. dosent jerk the wheel as hard as with a stock stabilizer. Seems like there is a bit less play in the steering wheel on the blacktop too.
Old Jul 21, 2009 | 02:07 PM
BostonX73's Avatar
BostonX73
I installed a fabtech dual on mine after the spring/shock/tire upgrade. My stock one was completely shot so it did make a big difference, no more wheel ripped from your hand when you go over rough potholes.
I went with the one that installs with the factory mount, just drill one hole - quick and easy. http://cgi.ebay.com/ebaymotors/00-05...4506.m20.l1116
Old Jul 21, 2009 | 02:09 PM
YellowSled's Avatar
YellowSled
What did you have to drill into? I didnt need a drill.
Old Jul 21, 2009 | 02:13 PM
chawkjr's Avatar
chawkjr
was talking about your lift
Old Jul 21, 2009 | 02:15 PM
YellowSled's Avatar
YellowSled
procomp springs 22210
Old Jul 21, 2009 | 02:17 PM
BostonX73's Avatar
BostonX73
mine took one hole in the top of the mounting bracket to attach the extension on. not a big deal, you set the extension in place, mark the hole and then drill.
Old Jul 21, 2009 | 02:18 PM
wallz's Avatar
wallz
I added the single rancho when I replaced the rest of the shocks. I do off road some and now wish that I went with the dual. The single still has some movement when you hit rocks and ruts while off roading. The single is fine for all other driving that I do and is good up to the 35" tires.
So if you want larger tires or off road get the dual kit.
Old Jul 21, 2009 | 03:11 PM
rlh68050's Avatar
rlh68050
Just installed the single Rancho (OE replacement). So far, I like it over the Ford unit. Seems to take some of the slop out of the steering.
